Question about Toshiba Satellite A135-S4427 Notebook
Toshiba A135-S4427 does not recognize 1TB hd
I upgraded the memory and hd on my A135. Now, After upgrading the Flash Bios, Windows Explorer does not see the drive larger than 120GB. How can I fix this?
  • 277 Answers
SOURCE: USB not working after resetting bios on toshiba a135
try using other usb port,,, .. run device manager and remove auknown device file... restart the computer...and also go to the cmos bios and find usb configuration the enable it..
Posted on Mar 14, 2008
scottyfixit
  • 186 Answers
SOURCE: cannot format hard drive
Memory is most likely not bad and Toshiba has a pretty good quality control on their laptops. Format it with the XP CD using the compatible but classic FAT 32 format then try installing 98 again. Possible that Win 98 doesn't know how to read that new of memory right in the format part of the installer. If it has a SATA hard drive, you might run into some trouble with SATA support when formatting down the road.
Posted on Jun 20, 2008
  • 148 Answers
SOURCE: Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Posted on Mar 02, 2009
  • 54 Answers
SOURCE: Memory upgrade not working
check front side bus for new ram & old ram ,sometimes if both are working on differant f.s.b. then also this can be happen
Posted on Mar 15, 2009
Crankstart
  • 696 Answers
SOURCE: My usb ports do not recognize my zip drives. They
Ok,
thanks for the clarification.
If the Ipod, which is essential a flash drive, works direct to the USB but the flash drive doesn't it's actually more likely that the flash drive has failed than any of the other possibilities. So, that being said, the next step is to plug the flash drive into a different computer and see if it works there. If it does let me know as there may be a driver problem on your computer, if it doesn't the flash drive has likely failed. If it has failed and there is nothing crucial on it, buy a new one they're inexpensive, if there is crucial data on it let me know and I will get you the contact info for a data recovery facility in your region(need to know your regoin as well). Regions being, North America, South America, Europe, etc.
Try this next step and let me know whether it works and I can advise you either way,
Chris
Posted on May 18, 2009
Can I get a memory upgrade?
Here you go:
http://www.18004memory.com/toshiba-satellite-a135-s4427.asp
Aug 16, 2010 | Toshiba Satellite A135-S4527 Notebook
Blue screen-Toshiba A135-S4427
the ram memory must be sufficient about 2GB & the processor must be dual core or core 2 duo.
if both condition your laptop follow then i think you should scan your lap top with anti virus.
Mar 03, 2010 | Toshiba Satellite A135-S4427 Notebook
I have a toshiba A135 with windows 7, It keeps freezing for long
I have had two toshiba machines recently with Vista installed and they freeze-up of become eraticly slow on startup. Turns out they both had bad hard drives!
Vista does, however need 1Gb RAM to run ok.
Mar 02, 2010 | Toshiba Satellite A135-S2326 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I upgraded my memory per Toshiba's website - installed the memory and the system will boot up, but then the screen goes blank - you can see the cursor, but nothing - I removed the memory and put back in...
when makes changes on memory ...always reinstall .and first go to bios and restore factory defaults ...optimal factory defaults ...
this will do to recognize the new modules ...and installing will aware the system about the changes..
Nov 13, 2009 | Toshiba Satellite A135-S2386 Notebook
Mar 15, 2009 | Toshiba Satellite A135-S4527 Notebook
Upgrade to a old laptop
max memories is 192Mb. that is not enough to run anything beyoond WIndows 98.
there is not update on the CPU for this model.
better off get a new one.
Dec 02, 2008 | Toshiba Satellite A135-S4427 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
BIOS password.
BIOS password article regarding Toshiba Satellite A135-S4427
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1816197xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
you actually should be able to "FLASH" your bios through windows.
Direct download page for BIOS
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1731516xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
Be sure to take your time to read the instructions and follow them dont have any programs open.
hope that helps!
Jan 29, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
