Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Breeze evaporative cooler does not cool - Mastercool 67471 Evaporative Cooler Air Conditioner
2 Suggested Answers
  • 40 Answers
SOURCE: Our Cool Breeze Evaporative air
They are very slow to start pumping water. will take up to 10 minutes
Posted on Apr 04, 2011
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
Mar 17, 2010 | Hamilton Beach Water Cooler with Storage...
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
The Mastercool cooler is not cooling. It is only
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Jul 11, 2009 | Speed Port-A-Cool 16" Evaporative Cooler...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Temp
Before an evaporation cooler will feel "cool" there has to be a greater difference in the outdoor and indoor temps and/or humidity. If the humidity is high and the temp cool < 80'f The "cool" wont feel cool because there is not much evaporation taking place.
Now if the temp goes to 90 or the humidity goes down under say 40% the cooling effect "feeling cool" will change and be more like its cooling. Part because of the difference in the temperature but also because the air can hold more humidity and it is pulling moisture off your skin.
When you talk about "feel" it is rather suggestive and always different for different people.
Aug 04, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
11 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
