Question about Pioneer X-smc3-s Music Tap Airplay Music System black
Buttons on pioneer xsmc3-s will not work and will not turn on
Will not turn on with or without remote
Why does my pioneer remote DDX3086 display work, but why can't I turn on my receiver or functions?
Check the remote control for its infrared emission.Check it with fresh batteries.If you wish to get more details about how to check a remote control, please visit this site.One among the posts has details about it.Surf the site with patience.
Aug 03, 2014 | Pioneer Televison & Video
My pioneer remote XXD3086 shows the display ,but doesn't function
clean the remote with an alcoholic solvent then try to look for any loose joint mostly near the LED transmeter then use your mobile phone camera to check whether light is visible when you press the remote buttons while directing it to the camera
Aug 03, 2014 | Pioneer New Original XXD3086 Remote...
Remote will not change channels
If you are using the original remote, it has failed.
Sep 26, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
Cant change the channel without the remote control
the child lock setting may be active use remote and go to the setting and turn them off. then the buttons should work again.
Sep 19, 2013 | Pioneer Elite PRO-940HD Television
I have a pioneer vsx d608 and the remote works only for the power and muting. I pushed some buttons on the face of the receiver and the all functions worked with the remote (not sure why). I turned it off...
I'm pretty sure the front face buttons have nothing to do with the intermittent success or failure of the remote to work - unless by some chance a given momentary control is 'stuck' on.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 20, 2011 | Pioneer VSX-D608 Receiver
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
HOW TO PLAY DVD WITHOUT REMOTE
try pressing stop while at the menu. then stop again. then hit play. that works for most dvd players
Sep 28, 2008 | Pioneer HTD-510 System
Cd pioneer dehp350
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
Dec 31, 2007 | Pioneer DEH-P3500 CD Player
Pioneer X-smc3-s Music Tap Airplay Music System black Logo
57 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
