Question about Fisher and Paykel GC36 Gas Cooktop
How to replace electrode - Fisher and Paykel GC36 Gas Cooktop
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
Aug 29, 2017 | Thermador Cooktops
One of burners can not ignite only having clicking sound.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Sep 10, 2011 | Jenn-Air JGC8430 Gas Cooktop
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
One of the igniters does not click. they were wet and popped the breaker over a week ago . all but one now clicks and lites burners. it was sparking a weekago and blowing the breaker.
Make sure the area of the burner base around the spark electrode is clean (use a fine sand paper). The little hole for the gas is open (use a paper clip). You won’t see a flame unless the burner head is on. If this doesn’t help, check the bottom of the spark electrode visually. Make sure the wire is attached to the electrode and is not loose (pull it a little bit.) If the wire or the electrode is damaged, replace it ($25). If not, locate the spark module and switch the connection with another one (they are different colors). If you get flame on the same burner, but not on the other one, replace the spark module ($60). When you work with electrical components, turn the breaker off. When you test, turn it on. Good luck.
Sep 14, 2009 | GE 36 in. Profile JGP962SECSS Gas Cooktop
Where can you order parts for Fisher Paykel GC36WAC Cooktop?
These people can get anything you need for Fisher-Paykel:
http://www.fisherpaykelparts.net
If you don't see it, ask them. They can get it.
Jan 28, 2009 | Fisher and Paykel GC36 Gas Cooktop
The ignitor is fractured how do I replace it?
hi thanks for the question 2 screws hold the igniter . pull bottom drawer out and remove the igniter replace it thanks the appliance doc
Sep 29, 2008 | Jenn-Air 35 in. JGC9536ADS Gas Cooktop
Ignitor not working
Yes, electrode is also called as ignitor. Both are same.
May 15, 2008 | Amana AKS3040 Gas Cooktop
Burners won't light
remove hte buerner cap and with a nail file or emory clloth try cleaning the electrode(sparker), sometimes a build up of carbon onthem will prevent proper lighting, also lool for cracks in electrode itself,if ther cracked they wont be very effective and need replacing
Feb 27, 2008 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Fisher and Paykel GC36 Gas Cooktop Logo
104 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
