Question about Samsung SGH-j200 Cellular Phone
Insert sim card connector - Samsung SGH-j200 Cellular Phone
Put in sim card and comes up insert sim ?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nov 02, 2012 | Cell Phones
Lg ks360 insert sim card problem
First All Check:
Last Option:
Sep 18, 2012 | LG KS360 Cell Phone
HTC SNAP SIM CARD FAILURE
First All Check:
Last Option:
Sep 01, 2012 | Cell Phones
LG C375 insert right sim
First All Check:
Last Option:
Aug 12, 2012 | LG C375 Dual Sim Card Cookie Tweet...
Offline mode on nokia e73
Most of this problem comes due to failure of Connection between the Sim card and the Sim card slot.Since, there is no separate Sim card IC the only thing you need to check is to clean the Sim card connector or sometimes the connector might bend.Moreover, you can at least insert other Sim card and try.Otherwise, contact nearest mobile repairing shop.Good luck.Thanks for visiting fixya
Aug 08, 2012 | Nokia E73 Mode Cell Phone
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
Dec 16, 2009 | Lands Phones
I have just received my new i phone and cant get the sim card inserted although i have followed instructions do you have to press down really hard to insert sim card and holder i done want to break...
NO!
dont do it hard!
if your sim card cannot be inserted, it might be a problem inside the si card tray.
please try looking inside with a good light, and try to find any obstacles that might be inside the sim connector.
but you should never try to press hard on the sim connector, doing so can surely harm you sim connector and you will not be able to use your phone.
a broken sim connector is NOT in warranty coverage.
Dec 10, 2009 | Apple iPhone Smartphone
INSERT SIM
If the display says "Insert SIM," it means that the phone has no contact with your subscription card (SIM card) that is inserted in the phone. We recommend that you remove the battery and the SIM card, and clean the connectors on the SIM card and the phone with a soft brush, cloth or Q-tip moistened with any type of unflavored colorless alcohol.
At the same time, check that the card is not damaged or worn in any way, in that case, the connector may not align with the connector in the phone. Please contact your operator / carrier for a new SIM card.
Sep 21, 2009 | Samsung SGH-c207
Reset my cellphone
Sep 21, 2009 | NEC L1 Cellular Phone
Samsung SGH-j200 Cellular Phone Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
