Question about Drills
Metabo drill I have a metabo khe26 drill that has barely been used approximately 3years old.it has the keycode security system on it but I have never activated it.In the first few weeks of use the drill stopped working and the keycode light on the top of the drill lit up as if security system was activated.On pressing the trigger the motor sounds as if to go but the chuck does not spin.sent it back for repair and seemed to be ok but has recently happened again.very frustrating as the drill has had very little use.any ideas .thanks
ohms
  • 1879 Answers
SOURCE: Monsoon CD stereo deck
Greetings,
Get a recommendation from the music shop that gave you the information about the CD System issue. They know better.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
SOURCE: Makita 6337D cordless drill problem
makita 6337d chuck stuck
can't get bit out
1st the bits would not tighten
Now so tight I can't remove bit
Posted on Aug 31, 2008
ccrozier_agr
  • 36 Answers
SOURCE: The chuck no longer spins on my drill
Hi your best chance is to try ebay for one with the motor gone.
Other than that best you can do is buy another drill the same so you will have a spare battery.
You could try Skill for a gear but it probably will be the price of a new drill.
Posted on Dec 02, 2008
danny_murray
  • 55 Answers
SOURCE: porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Posted on Dec 05, 2008
  • 12 Answers
SOURCE: DW988 1st and 2nd gear doesnt work, 3rd gear works
You may have put it back together wrong, but you may also need a new transmission. 99% of the power tools I work on where the gears are slipping is caused by the transmission or gear box (both names are used interchangeably).
Good luck to you!
Don-www.toolsandmachinery.com
Posted on Feb 24, 2009
Hi I have a metabo hammer drill une 2850 won't start
UHE2850 metabo first look if its the powercable have no phase fracture second is there depending 2 years warranty time on left ?
The switch or only dirt between brush and brushholder inside or an electronic assembly defect or the switch electric field armature . only a slide contact loose sometimes its not hard to find by metabo machines.
Mar 26, 2016 | Metabo Drills
Metabo uhe 28 multi code
http://www.metabo.com/International-Homepage-english-The-craftsman-s-brands-world.2786.0.html?&L=2786 You have no question but I do see the name metabo so hope this helps. It's the Metabo factory site where you can get parts breakdowns and more.
Jan 04, 2013 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Where can I buy a forward/reverse switch for a metabo right angle drill BE 622
Service Centers are listed on the Metabo Web Site. go to Metabo.US, then Services/Support, repairs and spare parts and in the center of the page click "Service Center". input your 5 digit zip code and it will offer you a list of all local groups that support the Metabo line.
Apr 05, 2012 | Metabo Drills
1/2" metabo hammer drill-
Did you check the carbon brushes?
May 17, 2011 | Metabo Drills
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
Metabo SBE750 hammer drill trigger sensitivity
The only possible sollution for this failure in this particular tool is to replace the switch. There are no additional electronics that could cause this.
Jan 14, 2010 | Metabo SBE560 1/2" 0 2,800 Rpm 4.5 Amp...
Hi, i hqave METABO 523 hammer drill that the
You're welcome to ship the unit to me for repair.
Contact me at info@taeckertindustries.com for more information
Nov 05, 2009 | Metabo Air Tools & Compressors
What is the switch at the back of the drill for
This switch will turn the impulse mode on or off. The impulse mode provides the burst of power needed to prevent slippage and allow easier drilling of tile and other hard materials.
Hope this helps.
Aug 10, 2009 | Metabo BSP15.6PLUS 15.6 Volt Cordless...
Drills Logo
32 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
