Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
Moving cutter - White Sewing Superlock 2000 ATS Mechanical Sewing Machine
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
Machine wont cut
Sounds like the blade didn't go in all the way. Try to reingage it. You should feel/hear a click when it is where it needs to be. Good luck
Jun 28, 2014 | Brother 1034D Mechanical Sewing Machine
Viking 936 Machine is not cutting fabric, but continues to sew. What can cause this?
More than likely the cutter/knives need replacing or are not coming up all the way to catch the fabric. Put a piece of fabric on the plate just before the cutters and turn the hand wheel slowly. Are the cutters coming up above the fabric and moving to below the fabric to complete the cut? If not, open the front cover/door and turn the hand wheel watching the cutters' movements. You should see the gears that travel up and down. Many times this area becomes packed with lint/fabric and binds the movement. I usually take a large needle and dig out the lint/fabric or whatever else is stuck in that area. You'll be surprised how much you will remove from that area.
Jun 20, 2014 | Husqvarna Huskylock Computerized 936
Cutter knife switch not moving to left on Brother 1034D
Not sure but try pushing the blade down with your finger then moving the switch to the left.
Apr 02, 2014 | Brother 1034D Mechanical Sewing Machine
Husqvarna embroidery diamond machine not cutting thread. Machine sounds like it is cutting thread but cutter doesn't move.
If the cutter is not moving when the cutter motor runs, there is probably a gear loose in the cutter mechanism. Take the machine to the dealer that you purchased it from, or the nearest authorized dealer. http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Make sure that you have your warranty card and purchase receipt. If a gear has broken, the mechanism is warrantied to the original owner for 20 years.
If you are the second owner, or the machine was purchased online instead of through an authorized dealer, an authorized dealer will give you an estimate for parts and labor and repair the problem for you.
Oct 16, 2011 | Husqvarna Designer I
Overlocker not cutting and, rolling fabric and tangling thread. It began when I went over a seam. It began to roll the fabric under rather than cutting. It then stopped and tangled the thread. Tried...
look on yu tube for a video on doing a rolled hem, and you'll see how to move the blades. perhaps you have accidently just moved them and need to engage them properly; good luck
Sep 14, 2010 | Singer Sewing Machines
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Sep 03, 2009 | Husqvarna Viking 1
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
