Question about KitchenAid 3/4 Hp Disposer
Will not turn on when switch turned on
Model 250
  • KitchenAid Master
  • 5,245 Answers
Why my disposal won't turn off
Sounds like the disposal is plugged into the wrong outlet. Try moving to the other socket on the wall plate.
Aug 20, 2014 | Garbage Disposals
Disposer wont turn off
That is the external switch that probably has welded contacts. Turn power off replace turn power on and smile it will work.
Aug 19, 2014 | Garbage Disposals
Garaabage disposal won't turn on
Check that it's getting power first, it may have jammed I am pretty sure some units have an overload cut out switch on the side to stop them burning out if jammed, check for that too.
Nov 30, 2013 | Montgomery Ward Alligetter
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
Garbage disposal is leaking out the bottom
You need to replace it, installation should be straight forward, just amke sure you get the same model so you don't have to modify the plumbing ththat you have in place already. prices range from $90 to $250
Mar 24, 2013 | Garbage Disposals
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
KitchenAid 3/4 Hp Disposer Logo
73 people viewed this question
Top KitchenAid Garbage Disposals Experts
Gene Haynes
Are you a KitchenAid Garbage Disposal Expert? Answer questions, earn points and help others
