Question about Golds Gym R Cycle Trainer 290 C Exercise Bike
Hard to pedal - Golds Gym R Cycle Trainer 290 C Exercise Bike
Brake pedal hard halfway hard to stop
Not sure why you have scanner readout, but the most likely culprit in the hard brake pedal/hard to stop category would be a faulty power brake booster.
Oct 09, 2015 | 1995 Dodge Grand Caravan
Why is it hard to push on the brakes
The most obvious cause for a hard pedal is simply not enough vacuum. Check the brake power booster by pumping on the brake pedal while the car isn't running. Continue pumping until you've "bled off" the vacuum from the booster. Hold the pedal down while you start the car. The pedal should go down a bit more beneath your foot. If it doesn't, then you should examine the connection between the vacuum hose of the brake power and the engine's vacuum.
Replace the brake power booster if the connection's fine, which would fix the hard brake pedal problem.
It may be your calipers need replaced. Check them for signs of wear. Look at the metal spring where the brake pads sit.
Apply tension to the pad and see whether you hear a pop. If you do, the brake pad is moving too much on the bracket. Replace the caliper. This could help the hard brake pedal.
Jul 09, 2014 | 2000 Isuzu Rodeo
Hard pedal on a 1968 cadillac and brake light comes on
The most obvious cause for a hard pedal is simply not enough vacuum. check the vacuum. please go to this site for info on hard brake pedal= .mpbrakes.com/techtalk/how-to-series/how-to-diagnosing-a-hard-brake-pedal Goopd-Day!
May 21, 2014 | 1970 Cadillac Fleetwood
Why is it so hard to apply brake pedal?
_______power brake booster, check vacuum to booster and the check valve for brake booster. primary symtom is high hard pedal that requires greater then normal pedal pressure to stop car. testing booster= pump brakes several times with engine off to deplete stored vacuum. turn on engine with pushing slightly on brake pedal. you should be able to feel the pedal fade away a bit, and then become firm. But not hard. if you feel nothing at the pedal when engine starts. Brake booster is not working. Good-day! make sure vacuum is going to booster with engine running. it may just be a bad vacuum line or check valve.
Apr 30, 2014 | 1984 Buick Skyhawk
99 dakota with engine running brake pedal will travel to the floor with engine turned off pedal is hard 1 inch from top
Sounds like a bad brake booster.. It's the large can behind the master cylinder. The fact you have a hard pedal with engine off is the key here.
Dec 11, 2017 | 1999 Dodge Dakota
Hard brake pedal. changed the mater cylinder. now all four brakes get stuck. any advise?
so is the pedal still hard? a bad brake booster can cause a hard pedal. Loosen the master cylinder about 1/4" from the booster if the wheels free up, then replace it.
Nov 27, 2010 | 2004 Nissan Sentra
Been having problem with brakes. I brake pad feels
Bleeding isnt going to help a hard pedal. If the pedal is mushy, and there is no air, the Master cylinder could be bad. If the pedal is HARD, there is no air. Press on the brake pedal several times with the engine off (5-6 times) now hold your foot on the pedal and start the engine, you should feel the pedal slightly give way under your foot. If you dont, and have a HARD pedal, the brake booster could be bad, but have professionals check it out before spending any money.
May 13, 2010 | 1993 Chrysler Town & Country
Stalls in reverse and brake pedal gets hard
Check your vac lines, also a hard brake pedal can be a bad brake booster.
Apr 17, 2009 | 1991 Chevrolet K1500
Golds Gym R Cycle Trainer 290 C Exercise Bike Logo
66 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
