Question about Tursion 10.2 Google Android 2.3 Tablet PC 4GB 512 MB RAM
Factory Reset How do I factory Reset this tablet? I already tried reset button it's not working just turns off and i have to turn it back on.
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    CANT POWER DOWN OR DO A FACTORY RESET
    How to Factory Reset Your Android Phone or Tablet When It ...
    www.howtogeek.com/.../how-to-factory-reset-your-android-phone-or-ta...
    Dec 6, 2012 - You can even perform a factory reset when your Android phone or tablet ... If You Can't Boot ... If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery ... If your device freezes at any point, hold down the Power button until it restarts.
    What to Do When Your Android Phone or Tablet Won't Turn ...
    www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
    May 16, 2015 - You can't just plug it in and try to turn it on immediately - you'll need to give ... How to Factory Reset Your Android Phone or Tablet When It Won't Boot ... To do this, you'll first need to power down your phone or tablet and then ...
    Dec 28, 2015 | Tablets & eReaders
    When I turn on the tablet I get the welcome screen for about 40 seconds and then tablet turns off and repeats this over and over without ever getting to home screen
    Did you attempt to root the tablet or install a different bootloader? If so, try again because it hasn't worked. If not, something has been corrupted, try to do a factory reset. Normally achieved by turning the power off, then turning the power back on while holding the home key and either the volume up or down button until you see an android.
    If you factory reset you lose everything. So if the option is there, first try the to clear the cache and dalvik cache.
    BTW, did you try the reset button on the edge of the case? Stick a pin in it. Try that first.
    Mar 21, 2015 | Irulu 7" Google Android 4.0 Capacitive...
    How do i unlock my tablet if i forgot my password?
    If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
    Jan 27, 2015 | Kocaso M9300 Google Android 4.2 capacitive...
    How do I get on to my son's IRULU tablet when he has forgotten the password?
    Can you follow this procedure:
    1. Turn off the tablet by pressing and holding the power for 30 seconds and tap shut down. 2. Press and hold power and volume up until an android menu appears 3. Use the volume keys to navigate and power to select. 4. look for factory reset and wipe data 5. restart the device and it should be back to factory settings!
    let me know how you get on!
    Jan 01, 2015 | Tablets & eReaders
    My nabi dreamtab wont reset why?
    There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
    Dec 20, 2014 | Tablets & eReaders
    I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
    While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
    Sep 15, 2014 | Tablets & eReaders
    How do I unlock my trio tablet! The code is a pattern and the tablet doesnt give me an option to retrieve the pattern or even reset it. Please help! Thx Kat
    Some tablets will prompt you to reset after you have tried and failed entering the correct password a certain number of times. You can try this, it could work too.
    Jun 26, 2014 | Tablets & eReaders
    Tablet is stuck on the screen that says android
    You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
    To factory reset:
    1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
    Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
    Locked out of my tablet by my child entering a new pass word...
    To unlock your tablet, you will have to perform a factory/hard reset of the device.
    Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
    To perform factory/hard reset please follow those steps:
    1. Turn the power off.
    2. Press and Hold the Volume Up and Power button at the same time.
    3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
    4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
    5. Select "wipe data/factory reset"
    6. Select "Yes -- delete all user data"
    * Allow several minutes for the factory data reset process to complete.
    7. Select "reboot system now"
    * Allow several minutes for the reboot process to complete.
    Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
    Tursion 10.2 Google Android 2.3 Tablet PC 4GB 512 MB RAM Logo
    51 people viewed this question
    Top Tursion Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Tursion Audio Player and Recorder Expert? Answer questions, earn points and help others
