Question about Sony Televison & Video
No power at all on my sony slv-d261p dvd/vcr
4 Suggested Answers
  • 4 Answers
SOURCE: Sony VCR date only goes up 2006
I have 2 SLV-696HF units that won't work after 2007. I have had people tell me that I'll have to "find" a previous calendar that will work, since there are only 14 different calendars in our Gregorian system, 7 for non-leap years & 7 for leap years. The problem we have with this, is that the internal VCR calendar won't roll BACK far enough. I wonder if SONY has a way of flashing these units to fix this problem?
Posted on Mar 03, 2007
SOURCE: Sony SLV-690HF (VCR), dead
It is the electrolytic capacitors on the power supply board gone bad. It is fairly simple to remove the board. Look at it this way. Even if you break it taking it out, you would have thrown away the vcr anyway. I simply experimented with mine and it payed off. I just replaced mine in the exact same model vcr you have(slv-690hf). The vcr would not power up. I replaced c202, c207, c109, and c208 and it works perfect again. They are the smallest ones. I'm pretty sure it was only one that was bad, but i replaced four of them just to make sure i got the bad one. You cannot tell by looking at them that they are bad. I just searched the internet and read where it's usually the smallest electrolytic capacitors on the power supply board in sony vcrs, that usually go bad. Sure enough, that was the problem. It is fairly simple to take the board out and do it, if you have time, patience, a little bit of know how, and a soldering iron. I used some capacitors from radio shack and some out of an old stereo crossover i had that did'nt work for the replacements. The capacitors from radio shack have a wire coming out of each end instead of both coming out of the same end. I just simply bent one wire over the top to make it work and cut them the same leangth. Be sure you use the same uf and voltage for the replacements.
Posted on Mar 29, 2008
SOURCE: Sony SLV-SE820 VHS VCR
o Front display,wrong functions on front buttons.
CAUSE
Corrupted data is stored in the NVM memory (IC605) or part of the data is erased.
The model option data flags are erased or set incorrectly.
SOLUTION
1. CAPACITOR AND RESISTOR REPLACEMENT NOTE
For continuous reliability, regardless of the symptom, ALWAYS check and replace if necessary C701 in the correct mounting position and ALWAYS modify R668/R669 from 10k to 4.7k.
1.1. Open the set and replace C701 "470µF 10V" (1-126-925-11)
1.2. Make sure to mount C701 in the correct way, the positive (+) side points to the edge of the MCB. NOTE THAT THE WHITE PRINTING FOR C701 ON THE MCB IS INCORRECT (REVERSE)!
1.3. Replace R668 and R669 "10k" (1-216-675-11) with "4.7k" (1-216-667-11).
2. OPTION DATA SETTINGS
2.1. Connect the unit to the AV input of a television with a SCART connection cable in order to enable the on-screen display.
2.2. Enter the unit into test mode: press the record button on the front panel, then press the menu button on the remote commander for 5 seconds until the option setting display appears on the connected television. The option display has 8 columns and 9 rows with decimal numbers.
2.3. Enter the correct option settings according to the model and model destination. Refer to the option setting table in this document or page 5-6E of the Service Manual.
2.4. The option number is selected with the FF, REW, STOP and PAUSE buttons on the remote commander.
2.5. Pressing the OK (PLAY) button on the remote commander activates the selected option number. An activated option number appears in reverse colour.
2.6. After all required option numbers are activated press the MENU button on the remote commander to save the changes. A message "Please wait" appears for a few seconds after which the setting is completed.
2.7. Turn the power OFF and back ON.
3. HEAD SWITCHING PULSE ADJUSTMENT
3.1. Remove the front panel.
3.2. Insert a VHS alignment tape (like KRV-4821PS).
3.3. Press the TEST button located behind the front panel at the left-hand side of the tape/display area.
3.4. Press the SP/LP button on the remote commander. The adjustments are operated automatically.
4. FUNCTIONAL CHECK
4.1. Re-assemble the unit and perform functional checks.
4.2. Check for correct language setting.
4.3. Confirm basic functions like Playback, FF, REW, etc.
4.4. Check for a noise-free picture quality in playback mode.
4.5. Switch the unit on and off for a couple of times.
4.6. Perform a timer record to confirm the function and picture quality.
4.7. Check the SmartLink function (if available with the connected television) by transferring the TV preset settings to the VHS recorder.
MODELS OPTION DATA SETTINGS
SLV-SE720D/SX720D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720E/SX720E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 27, 33, 34, 35, 40, 41, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720I
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 25, 26, 33, 34, 35, 40, 43, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 21, 26, 33, 34, 35, 36, 40, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SX727D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE727E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 32, 34, 35, 40, 42, 45, 47, 51, 60, 61, 63, 66, 69, 72
SLV-SE720N/SX720N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 19, 20, 36, 42, 45, 47, 51, 54, 60, 61, 63, 66, 69, 72
SLV-SE820D
2, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820E
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 29, 32, 34, 35, 40, 42, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820G
3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 23, 27, 29, 32, 33, 34, 35, 40, 41, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820B
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 21, 23, 26, 29, 32, 33, 34, 35, 36, 40, 45, 47, 48, 49, 50, 60, 61, 63, 64, 66, 69, 72
SLV-SE820N
2, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 19, 20, 23, 29, 32, 36, 42, 45, 47, 48, 49, 50, 54, 60, 61, 63, 64, 66, 69, 72
Posted on May 12, 2008
SLV-D350P DVD Player / VCR Combo remote codes
You may have to use a universal remote control.
Dec 21, 2017 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
Televison & Video Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
