Question about InFocus IN112 2700 Lumens SVGA 800x600 3000:1 DLP Projector - IN112
In112 remote not working
Remote turns projector on and off but does not advance the slides
How to unlock keypad without remote control
http://www.projectorcentral.com/pdf/projector_manual_6367.pdf
Mar 29, 2015 | InFocus IN112 Projector
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
Kodak 650 slide projector that won't advance the slides with remote
Don, Does the projector still cycle from the side (on-board projector) buttons?? If it does, then you have a bad remote (parts are still available from: www.micro-tools.com). If it will not cycle from either the remote or the side buttons, then chances are that you have a broken solenoid link. If you are not familar with the projector & proper disassembly, I'd contact a dealer. Again, you can still get the necessary parts from micro-tools. Good Luck !!
Jim
Apr 02, 2012 | Kodak Office Equipment & Supplies
On our Kodak 650 the remote will not advance the slides
Don, If the remote doesn't work & the projector cycle buttons do, then the problem is your remote. If neither the remote or side buttons work, then it is the LINK that connects the cycle solenoid the the cycle lever. Parts are still available from: www.micro-tools.com Good Luck !!
Jim
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Cannot get my Sharp Notevision remote to advance slides
you need an infrared receiver that plugs into your laptop to receive the signal ...honestly they arn't very reliable...go buy a targus presentation remote at staples for 39-69 bucks if you want areceiver i think i have one left
Nov 13, 2008 | Sharp Notevision XG-P10XU Multimedia...
Remote control problem
Yes, the computer won't advance the slides unless connected via the USB cable to the projector.
Mar 24, 2008 | Sony VPL CX11 Multimedia Projector
InFocus IN112 2700 Lumens SVGA 800x600 3000:1 DLP Projector - IN112 Logo
Top InFocus Computers & Internet Experts
Marko Kmeti?
Marko Kmeti?
Level 1 Expert
jasbo
jasbo
matt
matt
Are you an InFocus Computer and Internet Expert? Answer questions, earn points and help others
