Toshiba DVR3 DVD Recorder / VCR Combo
Problem for Toshiba DVR3 DVD Recorder / VCR Combo
I have a new element hdtv and a magnavox dvd/vcr.
By msjudy3059 on Jun 07, 2009
i have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Solution #1
posted on Jun 07, 2009
Not Rated)
SuperSandy
Rank: Guide
Rating: 93%, 8 votes
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Was this helpful?
Yes
No
Popular Solutions for Toshiba DVR3 DVD Recorder /
Questions and Unsolved Problems for Toshiba DVR3 DVD Recorder /
Do you recommend Toshiba DVR3 DVD Recorder / VCR Combo?
Answer
Answer
I would like to set channels other than the 1-6 for recording programmes. Presentley the dvd... (More)
Answer
I have a Toshiba dvd/vcr player model DVR3SU that gets an "error reading disc" message... (More)
Answer
I have purchased every type of disk that they make to see why my Toshiba VCR DVD Combo gives an... (More)
Answer
My problem is this: recently, Comcast has been converting all its customers to a digital signal and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
