Question about Avery Weigh-Tronix Weigh-Tronix Parts Scale - P/N 1140-13842 Cable
Weigh tronix E1010 service manual
I have one of these scales and need the service manual so that I can set up my printer for this.
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
Avery scale manual
Which model do you have? there are many manuals here:
Avery Berkel 1770 service manual http://the-checkout-tech.com/
Avery Berkel 3632USB users manual http://the-checkout-tech.com/
Avery Berkel 6700 series calibration guide manual http://the-checkout-tech.com/
Avery Berkel A-102 instruction manual http://the-checkout-tech.com/
Avery Berkel Conveyor Scale installation manual http://the-checkout-tech.com/
Avery Berkel CX-20 CX-30 CX-34 Series service manual http://the-checkout-tech.com/
Avery Berkel CZ-442 calibration manual http://the-checkout-tech.com/
Avery Berkel CZ-442 user manual http://the-checkout-tech.com/
Avery Berkel DX-342 service and calibration manual http://the-checkout-tech.com/
Avery Berkel E1005 users manual http://the-checkout-tech.com/
Avery Berkel E1010 users manual http://the-checkout-tech.com/
Avery Berkel E1070 Service manual http://the-checkout-tech.com/
Avery Berkel E1070 users manual http://the-checkout-tech.com/
Avery Berkel FX-50 users manual http://the-checkout-tech.com/
Avery Berkel FX-100 and FX-220 service manual http://the-checkout-tech.com/
Avery Berkel FX-220 user manual http://the-checkout-tech.com/
Avery Berkel G-203 user manual http://the-checkout-tech.com/
Avery Berkel G-227 service manual http://the-checkout-tech.com/
Avery Berkel GEC A-702 instruction manual http://the-checkout-tech.com/
Avery Berkel IX-100 IX-110 IX-202 IX-212 IX-300 IX-300P IX-302 IX-302P Operation and programming manual http://the-checkout-tech.com/
Avery Berkel IX-110 and IX-202 and IX-212 user guide manual http://the-checkout-tech.com/
Avery Berkel IX Series Customer Ready manual http://the-checkout-tech.com/
Avery Berkel IX Series parts list manual http://the-checkout-tech.com/
Avery Berkel M Series parts list manual http://the-checkout-tech.com/
Avery Berkel M Series service manual http://the-checkout-tech.com/
Avery Berkel Packscan user manual http://the-checkout-tech.com/
Avery Berkel RD-40RF user manual http://the-checkout-tech.com/
Avery Berkel TT-830 users manual http://the-checkout-tech.com/
Avery Berkel WI-127 service manual http://the-checkout-tech.com/
Mar 01, 2013 | Health & Beauty
Need manual for weigh of life scale
I have the instruction manual for the Weigh of Life scale. I can mail you a copy for only $5 (PayPal), as I have to go get copies made.
spspirk@gmail.com
Mar 26, 2011 | Digi Health & Beauty
Inaccurate weighing
mcdevito75, Most scales have a zero re-set screw or knob close to the weight indicator, if yours does simply re-set to zero with no weight on the scale, it may be a screw or small knob. If nothing than the scale might have to be replaced.
Jun 21, 2010 | Health & Beauty
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Avery Weigh-Tronix Weigh-Tronix Parts Scale - P/N 1140-13842 Cable Logo
265 people viewed this question
Top Avery Weigh-Tronix Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Avery Weigh-Tronix Office Equipment and Supply Expert? Answer questions, earn points and help others
