Question about Tools & Hardware - Others
Cardioline delta 1 plus ekg parts
Have himem problem tried on/off switch no result
  • 3,368 Answers
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
When I try to charge the battery in my Cardioline delta 1 Plus machine, it says "supply failure" and it also will not run on outlet power.
hi,
You have to check the power supply of you machine. Normally it will be a SMPS (Switch Mode Power Supply). If the SMPS is faulty then the machine will not work on outlet power and also will not charge the battery. That's why it displays supply failure. Check the SMPS if available then replace the same. For repairing the same can only done by an experience person in electronics. Because there are high voltage areas in the SMPS. So if you need to repair the same consult some one who is experienced in it.
ok
Apr 26, 2011 | Medical
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is alaronov@mac.com
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
Mar 31, 2011 | Schiller Welch Allyn Cardiovit At 2...
The cast aluminum fitting at the top of my Delta BS100 band saw that holds the tension on the blade is broken, how can I get a replacement part?
Hi David,
There are two primary ways to get replacement parts from Delta:
1. Through your local Delta tool dealer. Look in your yellow pages under "Tools" or "Contractor Supply". I suggest you avoid Big Box retail stores that sell Delta, as they generally won't be very helpful when it comes to repairs. If you are having trouble finding your local Delta dealer, the link in #2 below also has a "locate service center" tool.
2. Delta is a wholly owned subsidiary of Black and Decker these days, and they have an online parts lookup and ordering tool called SERVICENET. I have provided the link here. You can look up the part # for the part you need you need there and also the contact information for you local dealer. Call your local dealer, or simply create a login at SERVICENET and order it straight from Delta. Looks like the part you need is about $10, plus shipping.
If you find that the part is no longer available, Aluminum can be brazed by a skilled welder. You might go that route if there is no other option.
Hope I have been helpful.
Regards,
Grant in Iowa
Dec 20, 2010 | Garden
I have a AT2 Plus machine and cannot find my manual. the time and date is set incorrectly and I would like to change that. could you please assist me.
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
Jul 02, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
May 09, 2010 | Schiller Welch Allyn Cardiovit At 2...
Schiller AT-2 Plus, placed new paper in machine and machine keeps stating "out of paper" and will not print unless I hold down the manual print.
Your machine has the wrong paper in it or the paper sensor is not working properly.  There should be a black mark on the top left hand corner of each page.  The correct ekg paper and ekg repair is available from Medical Device Depot.
Feb 15, 2010 | Schiller Welch Allyn Cardiovit At 2...
Lower half or EKG would not print properly
You should purchase a printer kit. This is a common problem I have encoutntered on this machine and this machine is identical to the Seca CT6I. I have ordered the printer kit from Seca in the UK, the part number is 9740490024 at a cost of £70. It is a straightforward repair.
Sep 07, 2009 | Schiller Welch Allyn Cardiovit At 2...
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
The window on our schiller AT 2 plus ekg machine is too dark
When you first turn on the machine, hit the up or down arrows to adjust the brightness of the LCD screen.
Dec 09, 2008 | Schiller Welch Allyn Cardiovit At 2...
Tools & Hardware - Others Logo
70 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
