Question about Acer Veriton L480G Ultra-Compact Desktop PC (Black) (PSVA103040)
Replace HDD ACER VERITON L480G - Acer Veriton L480G Ultra-Compact Desktop PC (Black) (PSVA103040)
3 Suggested Answers
  • 2678 Answers
SOURCE: theirs no indication where about to put the power
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Posted on Apr 09, 2010
shadedarkan
  • 66 Answers
SOURCE: how do i replace hard drive on my acer veriton 3600gt
Depending on the hard drive, it may need to be 'initialized' before the computer can recognize it. This is best done by putting the hard drive in a working computer and going to, if using Windows, right-click My Computer, select Manage and clicking Disc Management where you will see the uninitialized drive.
You will need to create a partition and format it. Then your Acer should see it.
If you don't have a second computer then you will need to insert an operating installation disc in the drive and have that operating system's software format the disc.
Posted on Jul 04, 2012
When switch on the pc,no signal deducted display the screen is coming.
Then there is no output from the graphics card.
This needs replacing, as there should always be some output, even if it is wrong!
Try pressing F8 on start up. This will eliminate the graphics drivers and default to a plain VGA configuration and see if you get a display, if so your graphics drivers need changing.
If you get no display then the graphics card needs replacing.
Feb 26, 2015 | Acer Veriton L480G Ultra-Compact Desktop...
When power switch on the PC,only no signal display is coming on the screen. pl tell me how fix it up.
First check to make sure the video cable is properly inserted (also make sure that it is in the correct port - some PC's have two video ports - one integrated into the m/b and another added to the slot)
Try going into the BIOS to see if the video is working at all (try tapping on the DEL key when starting up) When in the BIOS check to make sure the correct video port has been selected
Sometimes some monitors can be reset by unplugging them, holding the power button for 15 seconds and then try powering them up.
How do i set up a acer veriton l480g desktop computer
Pretty straight forward
- Video monitor plug goes in plug on back of PC that matches
- Sound system - plug green plug into matching green port on PC
- Power cord in matching port on back of PC
- Internet cable goes in port that looks like cable plug
- USB plugs go in matching ports on back of PB
- they can only be installed one way
- It doesn't matter which port they are plugged into
Sep 04, 2014 | Acer Veriton L480G-UD7600C - Core Duo...
Acer m264 want boot up hdd no bios screen or anything
is there power coming?
if yes
remove the side cover and remove cmos battery and check if it is working, replace the battery
if that doesnt work remove the ram and check if it beeps
if it beeps replace the ram
May 20, 2014 | Acer Veriton M264-EC1200C Dual-Core E1200...
Can't remove hard drive from veriton m410;
You must slide the HDD holder first
Then remove the HDD
It maybe needed to tilt the HDD a little to remove it.
You can find more info HERE:
Dec 20, 2012 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
I have an Acer Veriton S670G the HDD has been locked ... how can i reset Bios password? I have tried the remove battery but it still requires a password.....
Don't worry please just visit the below link and fix your problem . This link will surely help to fix your problem.Here many common tricks and passwords are given which will help you out.
http://www.computerhope.com/issues/ch000235.htm
Please rate me if this solution works for you
Thanks......Have a great time
Aug 13, 2010 | Acer Veriton 5100 PC Desktop
Possible to install a SATA hard drive?
Yes it's possible you can Install thing is in your desktop mother board has a extra port or you can use Extranal HDD with USB Prot
Apr 09, 2010 | Acer Veriton 3600G PC Desktop
Acer Veriton L480G Ultra-Compact Desktop PC (Black) (PSVA103040) Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
