Question about Nintendo Video Game Consoles & Games
Errorcode 74030 - Nintendo Video Game Consoles & Games
Fault Code 010-319
Dear
Its the fuser related problem in secind level service. As the fuser assy.has replaced with a new one so but the problem remains. This has to be checked and clear all errorcodes stored in NVRAM during service peroide of the machine. As its very crucial operation on its software you may need the help of trained engineer to do so.
After clearing the errorcode the old fuser assy.may work.
Thanks.
Jan 29, 2015 | Office Equipment & Supplies
How do I get a manual for a skavn'jer street sweeper
Your best bet would to go directly through the manufacturer the info is below.
Home and Construction
  1. 1240 East Broadway Street, Drumright, OK 74030, United States
  2. +1 918-352-2137
Dec 11, 2014 | Vacuums
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Canon ir3570 errorcode e0007
u have to need replace ur fixing film
Jan 11, 2013 | Canon IR3570 COPIER FOR 220 VOLTS ONLY
Minolta 1501 errorcode COF32
Remove the black image unit and shake it so that the developer and toner inside of it is spread along the entire length of the image unit. reseat it install it correctly. if not get a new one
Sep 13, 2012 | Minolta CF1501 Copier
The RED airbag control light returns errorcode 47
Www.airbaglightoff.eu based in westmeath , cheap and plug
Feb 11, 2010 | 1999 Mazda 626
Load rom errorcode=-7
If you downloaded the game then the download is corrupted,because i downloaded a game that said the same thing so i took it off and downloaded the same game from a different site and it worked.
Jan 29, 2009 | Nintendo DS Lite Console
Mazda 323f errorcode 47 built 1999
Hey,
take a look at www.airbagmodul.com
They're working in Airbag-Simulators, Occupancy Sensor-Simulators and Seat Belt-Sensors.
Regards
Gerrit
Nov 27, 2008 | 1999 Mazda 626
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: IntelĀ® Chipset Software Installation Utility for IntelĀ® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
Video Game Consoles & Games Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
