Question about Canon I990 InkJet Photo Printer
Canon S9000 Ink Status Monitor gone AWOL after Waste ink Fix
Used the instructions provided by "fastrepairguide," posted Aug 05, 2007, and was able to get my printer up and running again. The side effect is that the ink status monitor doesn't seem to be working anymore --- when I go to print, the monitor opens but the ink levels are all the same, not showing what's low, etc. I'm wondering if it will still notify me when I'm out of ink, did this get turned off in the process?
  • 390 Answers
You need to manually tell the printer it has new ink levels, because when you change errors and settings, sometimes it will not automatically reset ink levels. cheers lilacgerry
Posted on Feb 06, 2008
Message on printer "Waste Ink near full"............. Where is the waste ink tank?
Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink FULL Reset (Should work with MP700/730/750)
This reset should be used once waste ink counter reaches full and lock-out occurs.
- To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
  1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
  2. Select "TEST MODE"
  3. Select "[8] ETC.."
  4. Select "[4] EEPROM CLEAR"
  5. Select "[1] INK COUNT"
  6. Press the [OK] button.
  7. Press the [Stop/Reset] button (Exits Service Mode)
  8. press the [ON/OFF] button (which resets the printer)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink absorber full
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How do I disable the ink moniter on my canon ipf600 wide format printer
Hello and thank you for using Fixya.
I just wanted to clarify a few things. You need to disable the ink monitor that pops up on your computer when you print?
Please let me know and give me all error messages (if any.)
Thank you,
Dec 06, 2009 | Canon imagePROGRAF IPF600 - large-format...
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
My Canon ip1800 ink absorber is full is there a quick fix
No .You must replace waste ink tank.
to get printout
Jul 01, 2009 | Canon PIXMA iP1300 Printer
Canon Pixma iP1800 Ink Monitor won't work
Have you enabling ink status monitor? Find the resetter at For clening the waste ink u must open the case first. wash the waste ink pad.
May 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
"the waste ink absorber is almost full"
Although the instructions posted here are for a different model, the procedure is almost the same for all ink printers. (I used it to fix my HP printer.)
Even if you can't get the ink pads out, you can try to dry them with paper towels.
Important: DO WEAR GLOVES!!! Put plastic bags around your work space. The ink IS evil and will not come off of anything it gets on.
The first time I did it without and it took forever to get my hands clean again.
Feb 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Printer problam
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them
for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44 etc service manuals, as far as ink pad replacement goes, they are the same.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Sep 24, 2008 | Epson Stylus C43SX InkJet Printer
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Canon I990 InkJet Photo Printer Logo
198 people viewed this question
old marine
old marine
