Question about Toys
Yiboo helicopter sync to controller - Toys
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
SOURCE: MY YIBOO MINI HELICOPTER ONLY SPINS ROUND AND
Same thing happened to mine if its the same problem. Check if one of the rotors is chipped.
Posted on Feb 11, 2010
emissionwiz
  • 75189 Answers
SOURCE: Yiboo AH-64 Gyroscope helicopter. Need to
I am sorry but we have no links to parts sites, my only suggestion is you contact the maker of the Helo.
Posted on Feb 15, 2010
SOURCE: remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Posted on Dec 22, 2010
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
My yiboo elicopter not respond from radio control
need new radio to try to match it translate this letter or receiver on the helicopter
Nov 29, 2014 | YIBOO Toys
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
Helicopter charging red light not blinking
The charger may not be plugged in all the way in either the helicopter or the wall.
Aug 22, 2012 | Toys
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
Dec 25, 2010 | Toys
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Yiboo ch-47 rc helicopter: Rear rotor has reduced lift, does backflip when attempting liftoff. Rear rotor turns more slowly when tapping the "collective" on the RC. Took skins off, all 4 shafts turn...
If you twist its rotors a little more then the lift can increase. But try to twist then only if they could be else you may become minus them and I would hate it.
Feb 26, 2010 | RC Remote Control Helicopter Ready To Fly
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
Toys Logo
19 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
