Question about Aten Technologies Aten KVM Switch CS692
Aten CS692 flashing lights
I have Aten USB KVM Switch, and i lost the user guide. I need to switch between the Pc's, what is that hot key i have to press to switch it. M.J Regards
You can check out here- there's a lot many Aten usb kvm switch, check your model and find out how to resolve your problem http://www.kvmstuff.com/server-management/kvm-switches/usb-kvm-switch.html
Jan 11, 2011 | Altusen Aten CS64U--4 Port USB KVM...
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Lost the instructions for the CS62U switch
here is the link to the aten website.
go to the select quick guide section and locate the model # in there,
p.s. its cs not c5
Aug 15, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Only 1 light on leads work and only 1 coputer will work
That is the way it is designed, only the light of the PC you are controlling will be lit. Once you switch using the hotkeys, the light switches as well.
May 08, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Dec 12, 2008 | Videk ATEN Master View 9834 KVM Switch
Aten Technologies Aten KVM Switch CS692 Logo
66 people viewed this question
Top Aten Technologies Computers & Internet Experts
David Payne
David Payne
Are you an Aten Technologies Computer and Internet Expert? Answer questions, earn points and help others
