Question about Eric MacKinnon Travel Brain
Server refused the connection
I cannot seem to get travel brain to load at all on either of two browsers. Chrome says "The server refused the connection," and Safari just has an empty screen. Ideas?
How To Fix Google Chrome Error 105?
Error 105 indicates that Chrome can't find a DNS server.
Without a DNS server, a browser can't find a web page using a domain name (such as google.com) and therefore cannot surf the web.
If you have another browser, such as Edge, Internet Explorer, or Firefox and they cannot reach google.com either, then you are either not connected to a network with internet access or your browser has been hijacked.
If you are on a windows computer, use Windows+R or click in the Run box on your start menu and type cmd to pull up a command window. type >ping google.com and hit enter... if it pings the address successfully, then you have DNS and your browser has been clobbered.
Otherwise try connecting to another network, contact your network administrator, or examine your TCP/IP settings for your current network adapter and set your Preferred DNS server to 8.8.8.8 (google's DNS server) and the Alternate DNS to 4.4.4.4 (also google). This should give you access to the whole internet via domain names.
Sep 21, 2017 | Google Computers & Internet
Oops! Google Chrome could not connect to secure.twitch.tv
Change the DNS Address
1.
Right click on Network icon and click Open Network and Sharing Center.
2. Click "Change adapter settings" (top left side).
3. Now right click on your active Network Connection (WiFi, LAN, Ethernet, etc.) and click on Properties.
4. Select "Internet Protocol Version 4 (TCP/IPv4)" and click Properties.
5. Click Use the following DNS server addresses: and add below server addresses and click OK.
  • Preferred DNS Server: 8.8.8.8
  • Alternate DNS Server: 8.8.4.4
Dec 31, 2013 | Google Chrome
Cant play the game the loading is slow and keeps being interupted.
First check your connection. If you have unstable or slow connection, it might be the cause. Second, use other browsers. Sometimes Google Chrome or Firefox loads slowly. So try it on other web browsers. Third, it's the Ninja Saga server who has the problem.
Sep 12, 2011 | Ninja Saga
Chrome will not connect, displaying this error, Error 102 (net::ERR_CONNECTION_REFUSED): The server refused the connection.
Scan your computer for malware/viruses and remove anything harmful you find (if anything)
Clear cookies.
Make sure Google Chrome is allowed by your antivirus and/or firewall.
Aug 21, 2011 | Google Chrome
The Proxy server is refusing connection,. Unable to connect to the Proxy server. Error 130 (net : Error_Proxy_Connection_Failed)
Google Chrome may not be using a proxy from your ISP odds are that it is not so you will have to go into the tools and options and then select connections section and disable the connection for proxy server usage just un check it not to use any proxy servers that is what is going on. I hope that this assisted you. Thanks for using FixYa! John
Apr 13, 2011 | Google Chrome
The proxy server is refusing connections
If it's a free proxy I would be very cautious. Many are run by hackers and will plant bots and other malware on your computer.
Jun 08, 2010 | Dell Inspiron 1525 Notebook
Error 105 (net::err_name_not_resolved): The server could not be found.
This error looks very similar to one found in Google chrome. Hope it is related to google chrome. you can try other browsers like iexplore or firefox.
Chrome has this error following some firewall connections. Refer to link if it is realated to Chrome
http://groups.google.com/group/google-chrome-help-troubleshooting/browse_thread/thread/26c86740a23a1457
May 15, 2010 | Microsoft Windows XP Media Center Edition...
My webpage is not loading anything google....is there a problem?chromes not working and my other browsers aint loading any page associated with google
1. Go on start menu and find "control panel" 2. Once you've clicked on "control panel" click on "network and sharing centre" 3. Click on "view full map" 4. Check it says "computer name"(Or your name, Or what ever you saved it as) > "Server name" (again what ever you saved it as) > "Internet" 5. If it does not say internet go onto your browser and type in your IP/server code for example 193.161.3.5 this should allow you to administrate your connection. 6. If your wireless make sure it's picking up the signal.
If this does not work please contact your server provider.
Hope I helped Dr Reed
Oct 13, 2009 | Google Chrome
Proxy Server Refused Connection Firefox is configured to use a proxy server that is refusing connections. ...
If you're using Firefox, click on "Tools" at the top of the page, click on "Options" which is at the bottom of the list that comes up, then click Advanced, choose Network from the four tabs below that. There should be a sentence "configure how Firefox connects to the Internet". Click on the button next to it that says "settings". and make sure that "Auto-detect proxy settings for this network" has a dot in the little circle. If not, click on it and click on OK.
You may have to shut down Firefox (your internet browser programme), then try getting in again. Should have sorted it.
Nov 29, 2008 | Computers & Internet
Eric MacKinnon Travel Brain Logo
369 people viewed this question
Top Eric MacKinnon Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you an Eric MacKinnon Facebook App Expert? Answer questions, earn points and help others
