LG LED true flat the screen is black looks like water waves on the screen no buttons work blue power light doesn't come on but has power there is no message on the screen just black
LG LED tv black screen
led light under screen is not glowing,,check led lights or its related circuit
Dec 28, 2015 | LG 50LN5750 50-inch Widescreen Smart LED...
Model 50LN5700-UHBUSYLJR. Why is there sound but no picture??
Chance your led strip if you are sure that your power supply led module is working perfectly
Jul 20, 2015 | LG Televison & Video
20 minutes worked then it just went black
Not a Solution but may help! Honestly more info is needed so We can narrow your problem down. Lets start with this. Note I havent looked up the manual for your model but This should help. Mostly Standard. Like traffic lights.
First, Locate your power Led, Note Color of Led. Red?(off) Green/Blue (on)Yellow (Standby). If you have a manual handy the Troubleshooting section describes these and what they mean.
1) If no power led is lit then, its either your power receptacle,(highly unlikely) fuse on power supply or power supply. Needs service.
2) If there is a power light. Note the color and if the led changes color or blinks after you hit the power button. ALSO,
B) Does the screen stay black, does it flash. or nothing happens? Note any changes in the led power light color and note it down.
If there is power and you still have no light, could be any of your boards. But we need to first verify power.
Hope this helps. Will
Jun 06, 2014 | Coby TFTV3227 32 in. LCD TV
Turned on my 42" LG
hi,
Yor tv has problem with back lighting. This tv uses LED (Light Emitting Diodes) as back light. These back light modules are not availabe in the maket now. You have to contact the authorised servicing centre for the same. You will get an idea how it works by the help of following picture.
Sep 16, 2011 | LG Televison & Video
HELLO I have recently made an Blue LED writing sign, at close up its fine, but the more further i go away from it , it becomes blurry and hard to read. please help
LED's have a very specific wave length that defines the color, and blue isn't that sharp. Plus the type of LED's itself may not be of the right angle. Together this makes for looking fuzzy at a distance. A different color blue (different manufacturers have slightly different colors of blue and each are slightly different wave lengths) and/or a different angle of lens might improve the legibility of the sign.
By the way this is also true to a point about octics, your eyes for the color blue. Think of how much harder it is to read lighter blue ink print than it is to read either black or red....
May 17, 2011 | Kitchen Appliances - Others
LG LED 4600 - TV power ons but nothing comes up on the screen. No sound No picture. The remote power on light indicates Red or White as and when we press the power on remote button. Please suggest
Do you at least get a blue screen? Usually with no picture you get a blue screen. Try hooking up a DVD Player to it and see what you get... Good luck...Keep me posted ..Sincerely HDTV GURU JAY.
Mar 16, 2011 | LG 42LC2D 42 in. LCD HDTV
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
