Question about Panasonic VIERA Televison & Video
Find model number panasonic tv tbm2ax166 - VIERA Panasonic Televison & Video
How do i know this code number for panasonic TV Model TC-21PS70P LA42
You are seeking a proprietary Panasonic part number. If you supply Panasonic with the model number of your TV, they may be able to identify the part but is likely that Panasonic will be the only source for a replacement.
Jun 05, 2014 | Televison & Video
How do I hook up my magma box DVD player to my panasonic pv- C2021 tv I don't have remote so how do I get to menu
TV Remotes Panasonic
I think the best answer is - get a new remote. The link is for Panasonic remotes, however, I did not locate your Model number, so double check the model number of your TV.
May 31, 2014 | Televison & Video
Sir i want panasonic tv remote model number my tv model pc21psr
There is no Such model set for Panasonic Till time. Your set might have a duplicate one from China.
Aug 30, 2012 | Televison & Video
My 1992 big screen panasonic cinemavision tv keep cutting off...help!
If a 1992 model a lot of the parts are no longer available at all---what is the model number of your TV?
Most of Panasonic sets the power light will if shuts off blink a specific number of blinks--a error code.
May 27, 2012 | JVC AV-27D203 27" TV
How to reset a panasonic 53 inch tv?
Hello
What is the excat model number of your Panasonic TV? You can get this number from the back cover of your TV. Without it, how can one post a solution to your problem? Inform me this number by Fixya comment box; please.
Feb 12, 2012 | Panasonic Televison & Video
How do I know the model of my projection panasonic tv
All sets made by Panasonic and others have a label on the back with model number, serial number and date made. The serial number only is used for non technical purposes.
If you have a problem be sure to post the model number so I or another expert can give you help.
regards, sd tech
Sep 29, 2011 | Panasonic PT-52LCX65 44" HDTV
How much does my panasonic 32" LCD weigh?
We cannot tell since you do not provide the model number of the TV, the 'LG RZ32LZ50' is for LG TV. Please repost the make and model number so we can look up the spec for your TV, or just GOOGLE your TV model number.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 11, 2010 | LG RZ32LZ50 32 in. LCD Television
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
