Question about Sanyo SR-4911M Compact Refrigerator
Kenmore mini fridge - Sanyo SR-4911M Compact Refrigerator
Brand new Kenmore mini fridge is making an annoying whistling noise
If Sears did suggest a solution for the symptom you describe it would probably be to replace the fan.
Nov 21, 2013 | Kenmore Refrigerators
Right side of my mini fridge is very hot
HI.CHRIS.i would think is normal if the fridge is working fine.this one must have a built in condenser.hope this helps.Ali
Jun 29, 2012 | Kenmore Refrigerators
How do you change the door gasket on a kenmore #564.91615100 mini fridge?
pull back the seal and you will find a stream of screws undo them all and the panal will fall off peal the old seal off and replace with new re asemble as per reverse order
best of luck
please remember to rank my reply
Dec 01, 2010 | Kenmore Refrigerators
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
My mini fridge is a big freezer.
It is the temperature sensor. It is normally attached to the evaporator itself (the freezer part that gets cold).
Jan 06, 2010 | Kenmore Refrigerators
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
My Kenmore black mini fridge, door will not stay sealed shut
Got too much stuff in it.
Not level or is tilted forward.
Door is warped.
You keep opening it.
Am I getting close?
Sep 08, 2009 | Kenmore Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Sanyo SR-4911M Compact Refrigerator Logo
21 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
