Question about Logitech C170 Webcam
C170 *.inf file - Logitech C170 Webcam
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
Computer cant detect the printer
Go to C:/windows/inf and look for files called oemXX.inf oemXX.pnf.
Open the .inf files one by one and look for the EPSON label in them and when you find one just delete the .inf and .pnf file equivalent. There might be more than one EPSON files in the inf library.
Then unplug the printer, restart the computer, and the add wizard should pop again when you replug the printer.
Hope this helps.
Jun 21, 2011 | Epson TMT70 TMT70 C31C637001 Printer
Whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
My kingston micro sd card has autorun.inf. Is it safe ?
Hello
OK, the autorun.inf is a file that you should not actually be able to see, as it should be hidden, but it is normal.
Have a look HERE.
But, in some cases this is a duplicate virus file, so, best is to scan this drive, and let your virus protector delete it if it is a virus.
Hope this can be of help.
Kind regards
Andrea
Sep 10, 2010 | Computers & Internet
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
Where can i get the inf file MDMCBX4.INF? FOR UPGRADE OF AR-65
This sounds like a driver file. Have you tried the buisness copiers section of sharpusa.com?
Or if you have the drivers make sure thay are at the top level/root level of your C: drive and use the printer install wizard instead of the setup.exe
Jul 07, 2009 | Sharp Office Equipment & Supplies
Unlock code for SGH-C170
hi im josh  in cebu phils. may i help you? Friend try to download your unlock coded for you SGH C170 to this site below: http://www.cellcorner.com/ Good luck hope i helped you.
Mar 13, 2009 | Samsung Cell Phones
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
Logitech C170 Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
