Question about Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher
Miele inspira intake - Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
Detergent tray doesn't open during operations.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 31, 2011 | Miele Inspira G2140 Dishwasher
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
My brand new Miele dishwasher door wont saty down when loading and unloading - tonight was the last straw as it shot up and has really hurt my forearm!!! Please tell me what I can do to sort this out =...
you can tension the door springs or release tension by a screw at the top ....you will have to look for it check the book for directions....you probably have a model made for a door panel to be fitted and dont have the panel fitted yet...
Feb 10, 2011 | Miele Inspira G2140 Dishwasher
2009 year Model 2182; middle spray arm came loose; when reattached, does not turn properly or spray water; makes knocking noise with door closed.
The parts that hold the spray arm have worn out...to get it working right you will need to get a new arm and the parts that it attaches too and you will be fine...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 03, 2011 | Miele Inspira G2140 Dishwasher
Model Inspira G2140 SCU There is a residue on dishes and glasses Water come on is hot but does not clean
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Miele Inspira G2140 Dishwasher
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Inspira Series Model G2140 U All program cycle indicators are on. I unplugged the dishwasher for 60 secs. and tried a hot/pans cycle and all the lights returned. What can I do? Thanks, Leo
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Feb 27, 2010 | Miele Inspira G2140 Dishwasher
Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher Logo
14 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
