Question about Miele G892SC SS Dishwasher
Miele inspira g 1180 intake drain - Miele G892SC SS Dishwasher
5 Suggested Answers
SOURCE: intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Posted on Sep 04, 2009
  • 12 Answers
SOURCE: Miele Dishwasher Intake/Drain Red Flashing Light
Does it fault out in the beginning, middle or end?
Posted on Nov 17, 2010
SOURCE: Miele incognito won't drain. Intake
i also found my miele wouldn't drain after replacing a garbage disposal. it turned out I forgot to knock out the plug on the disposal where the diswasher discharges....Doh !....
Posted on Nov 28, 2010
  • 251 Answers
SOURCE: Miele G892 SC Touctronic dishwasher, intake/Drain
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Posted on Jul 01, 2011
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
Model Inspira G2140 SCU There is a residue on dishes and glasses Water come on is hot but does not clean
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Miele Inspira G2140 Dishwasher
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Inspira Series Model G2140 U All program cycle indicators are on. I unplugged the dishwasher for 60 secs. and tried a hot/pans cycle and all the lights returned. What can I do? Thanks, Leo
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Feb 27, 2010 | Miele Inspira G2140 Dishwasher
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G892SC SS Dishwasher Logo
43 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
