Question about Rancilio Silvia Espresso Machine
How to reset the boiler on rancilio epoca de 2gp
SOURCE: rancilio silvia
It more likely is the automatic boiler shut off if the boiler overheats. Just reset the boiler.
Posted on Nov 08, 2007
IrishDruid
  • 2712 Answers
SOURCE: Rancilio Epoca DE 2 group espresso machine
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
Posted on Jul 01, 2008
EsWorld
  • 1618 Answers
SOURCE: when i turn on my rancilio epoca all the lights keep blinking
That is normal until the machine heats up, its just saying that it is warming up.
Posted on Feb 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Epoca S1. Constant click noise??
It is the sound of the pressure stat turning on and off, that is normal.
Posted on Aug 14, 2009
EsWorld
  • 1618 Answers
SOURCE: rancilio epoca 2 head machine. Lights are flashing
Machine is not heating, the lights should flash until it heats up to 1.2 bar on the top gauge. If not check the water level in the machine and check the red reset switch to see if the thermostat tripped.
Posted on Jul 02, 2010
My Rancilio Epoca ST1 would not turn on yesterday so I unplugged the machine and plugged it back in and it started right up. Today I turned the machine on and it warmed and pressured up as usual and then...
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
Jul 12, 2011 | Rancilio Epoca ST-1 Espresso Machine
New rancilio epoca s tank I turn on the switch 1, the boiler is filled and is activated. ok once the boiler is filled i turn resistance switch 2 ...but it doesnt work.
It should take about a 1/2 hour to warm up, are any lights flashing? Is the light on the second switch green? If not you might want to take off the left panel and find the thermal reset. Its mounted to the top side and has a little red button facing you. Press that to reset the unit.
Mikey@espressomachineexperts.com
Feb 24, 2011 | Rancilio Epoca ST-1 Espresso Machine
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
My rancilio epoca will not turn on
Sounds like the reset switch tripped, remove top panel and reset red push in switch close to the element.
Nov 26, 2010 | Rancilio Epoca ST
My rancilio epoca s1 won't start.
HI
Without being in front of it, there are a couple of things to check.
1. There is a reset button on top of the boiler. It is a black top with a red button in the center between 2 wires.
2. The water tank needs to be emptied and then refilled.That is the first things I would check.
Oct 02, 2010 | Rancilio Epoca ST-1 Espresso Machine
Water safety sensor preventing heat up of boiler?
If the red light is on then the machine is not getting water and or level is low in boiler. Try this remove the bell looking softener and run it under the faucet to see if water flows through, it could be that is blocked and not letting water through, and if so then the reset switch for element might have tripped because machine has low water.
Jul 02, 2010 | Rancilio Epoca ST
My Rancilio Epoca E1 espresso machine has no steam
It is possible that the reset connected to the boiler tripped.
Sep 29, 2009 | Coffee Makers & Espresso Machines
Rancilio epoca - heating element continue to stick on
It's the thermostat for certain.
Te release valve is put there it be sure the tank pressure doesn't get too high such as to cause a steam explosion/rupture of the tank.
Jan 30, 2009 | Rancilio Epoca ST
Jun 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
47 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
