Gould type jb 101-2426 120 v 60 hz - Heating & Cooling
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why goulds septic pump buzzing
check for foreign objects jamming the impeller. have the motor tested for failure.
Jun 07, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Gould water pump
I service all sorts of Goulds water pumps for a living but will need some more info to troubleshoot your problem. For starters would need to know what voltage feeds it, single or three phase, horsepower, type of controller (pressure switch, Variable Frequency Drive, Three phase across the line start etc.), what you are doing with it, pump model number, motor frame number, etc. etc.
May 12, 2013 | Cars & Trucks
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
What type of graphics card to buy for an emachines EL1600
Take the card back - take the pc tower with you - take the cover off and show the sales man where you need the card to fit - you do not have PCI slots - sorry - but there is a pc video card that will make you happy - just get one made for your set up-
Apr 02, 2010 | Computers & Internet
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Jun 08, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
