Question about Smeg Ovens
How to change the light bulb on sa398x/1 - Smeg Ovens
Can you tell me the light bulb type/size and how to change it please?
Refer your question to a local appliance parts supplier or an Evolution dealer/supplier.
Jun 07, 2016 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
JJW9527BAQ change light bulb
40w appliance light bulb.
Jan 12, 2012 | Jenn-Air Ovens
The lightbulb in the microwave needs to be replaced. How does one get at the bulb to change it?
At the following site, http://www.ehow.com/how_4967054_change-light-bulb-microwave.html
detail instructions can be found for changing the light bulb in your microwave.
Give it a try.
If this works for you, please give me some positive feedback.
Thanks!!
Jan 25, 2011 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    How do I change the light bulb in the oven
    You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
    Apr 24, 2009 | Philips Ovens
    Noisy fan in Smeg oven SA398X
    Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
    Apr 18, 2009 | GE JGRP17 Gas Single Oven
    Can't change light bulb
    yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
    Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
    Oven light
    how to change the light bulb in the oven of the stoves panache 6oosidlm
    Sep 02, 2007 | Ovens
    Ovens Logo
    Top Smeg Ovens Experts
    ashburton
    Jason Harris
    Jason Harris
    Are you a Smeg Oven Expert? Answer questions, earn points and help others
