Question about Supersonic SC-178DVD
Sc-178 factory reset - Supersonic SC-178DVD
Hod do I factory reset my karaoke player
CAVS USA User Forum - H...
cavsusa.com/kb/index.php?action=sitemap&letter=H&lang=en
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
CAVS USA User Forum - W...
cavsusa.com/kb/index.php?action=sitemap&letter=W&lang=en
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ...
www.fixya.com > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
Acesonic DGX-109 USB Multi-Format Karaoke Player with ...
Dec 06, 2015 | Televison & Video
Halfway city between hayesville nc and calabash nc
The closest to halfway I would say would be Newberry, SC, which is 178 miles from Hayesville and 208 miles from Callabash. For travel purposes if one wants to stop for the night I would say Columbia, SC which is 216 miles from Hayesville and 171 miles from Calabash.
Jun 14, 2015 | Cars & Trucks
I need a universal code for a supersonic dvd player SC-170
Lets see what do i have stored in my head??? Hmmmmm nothing look in the book
May 24, 2015 | Supersonic Sc-178 7 Portable Dvd Player...
Can a sc-72jb be reset using a connection to another computer?
you will usually find the factory reset option under the privacy settings.
no need for a computer and the answer to your question is no.
Nov 28, 2014 | Supersonic SC-72JB 7" MID w Android OS...
Our Phillips flat screen tx has stopped working, no sound or picture, but light is green and sounds like it will start.
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 05, 2014 | Philips 47PFL5603D/27 Flat Widescreen TV...
I have a supersonic dvd player and it won't spin at all.Model no sc-178 dvd
sorry to say but most likely case is bad motor or turntable issue of some type. unless expensive unit cheaper to buy a new player.
Nov 03, 2012 | Televison & Video
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Supersonic SC-178DVD Logo
20 people viewed this question
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
