Question about HP Compaq EVO D510 Intel Desktop PC - Intel Pentium 4 2.4GHz, 512 DDR, 40GB HDD, CD-ROM, 10/100 LAN,
Green lights what does it mean when the top light is blinking?
2 Suggested Answers
  • 120 Answers
SOURCE: TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Posted on Oct 13, 2009
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
I replaced my fuel injector # 3 and all spark plugs on my 1991 Nissan 300zx non turbo and my engine light is still on and my car still idles really weird and it smells like gas so badly all the time now...
the ecu is located behind the passenger kick panel , there is a little window at the top of it which has 2 lights in it red and green, turn the key to the on position, do not start engine, push gas pedal all the way down then release, the lights will start blinking, for example if you get 3 green blinks and 2 red blinks that means code 32, 5 green and 1 red code 51, there is a list on the front of the ecu that tells you what each code means
Jan 20, 2018 | 1991 Nissan 300ZX
Energizer model chdc7 charger green lights flashing very fast
Single Blinking Light means it is charging, eventually the top green light will start blinking to show that it is half way charged. If both lights blink at the same time repeatedly this means there is something wrong and the charger is not charging the batteries.
Sep 24, 2012 | Cameras
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Oct 13, 2009 | HP DeskJet 5550 InkJet Printer
HP Compaq EVO D510 Intel Desktop PC - Intel Pentium 4 2.4GHz, 512 DDR, 40GB HDD, CD-ROM, 10/100 LAN,  Logo
11 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
