Question about Pioneer Audio Players & Recorders
Error Code B17102
Hi I'm trying to connect to my Pioneer VSX-1122-k with icontrolAV 2012 via a AS-WL300 wireless LAN converter and keep getting Error code B17102. has anyone had the same problem or better still any solutions? Thanks
Gigatech
  • 259 Answers
SOURCE: Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
Posted on Dec 12, 2007
SOURCE: pixma mp600r scanning setup
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
Posted on Feb 02, 2008
Templarius
  • 86 Answers
SOURCE: siemens gigaset se587 4 port
Go into 'control panel' then 'network connections' and right click on your 'local area connection'. Select 'internet protocol' at the bottom of the list and click on 'properties'. Ensure that 'Obtain an IP address automatically' is selected. Run through the installation disk again and my guess is it will work. Despite this being relatively simple no one at tiscali suggested this over the course of 2 weeks which I found astonishing.
Posted on Apr 10, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Posted on Nov 08, 2008
  • 30 Answers
SOURCE: keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Fixing 401 errors - general
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
Posted on Apr 11, 2009
Pioneer elite. get CEC100 error. which says that "the device cannot be operated. please check the connection"
I have a Pioneer PDP-LX5090, Kuro Flatscreen TV, connected via HDMI4 on a Pioneer AV-receiver VSX-LX60.
By connection a Chrome cast on one of the HDMI ports of the AV-receiver I got the same CEC100 error with the same message "device cannot be operated. please check the connection". By disconnection the Chromecast from the USB current feed, the problem dissapeared. Hope this can help you.
Jul 01, 2017 | Pioneer Televison & Video
Vsx-1122
Did you take the default configuration when you set up the device? Did you change anything? Go back to the setup and see if you have modified any of the output sections. Also check for the TV being plugged into the wrong place...
HDCP is "High-Bandwidth Digital Content Protection" via HDMI connections, I believe. In short it's saying that it has some kind of error that is a copyright violation, as a guess. You might look it up on the Pioneer site for a better explaination.
Jack
Aug 06, 2014 | Pioneer VSX-1122-K Receiver
I have a as-wl300 wireless LAN converter by pioneer for 5 monts and suddenly stop working the power, wps and wireless indicators will not turn on
Check to make sure that all of the power connections are tight, both on the back of the converter and the wall. Change the location of the plug if that does not help.
If this does not work, replace it.
Mar 15, 2014 | Computers & Internet
VSX-1122 Pioneer Receiver keeps turning off randomly
Sounds like one or more of your speakers are bad.
Jun 04, 2013 | Audio Players & Recorders
I am trying to scan a document using the Canon PIXMA MG6120 that is connected via wireless LAN to my laptop. I get an error message on the laptop as follows: START OF ERROR...
Your firewall block the communication. You will need to get into your protection software and allow 'full' access of MP Navigator (EXT)
Aug 03, 2011 | Canon PIXMA MX870 Wireless Office...
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
35 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
