Question about Frigidaire FSC23F7D Side by Side Refrigerator
Water dispenser not working
I have a water dispenser and ice maker on this frig that has never been hooked up.  I plumbed the water to the unit and ice maker stated to work but I could not get the water to come out of the spiket on the front for drinking water.  What coulf this be?
The water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Posted on Jan 06, 2008
    Problem Solver:
  • 3 Answers
Check for a frozen water line.
Posted on Nov 09, 2007
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
My water will not come out of the water despenser
start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze.
Dec 28, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not working water is coming out through the front for drinking but water does not seem to be going up the line for ice in the rear of the frig
On units with both ice and water dispensing there is what is called a dual fill valve. One side of the valve can go bad, which allows water to dispense but no water flows to the ice maker. Common problem. Just search for the part using your unit's model number.
Dec 01, 2009 | Washing Machines
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water in door will not work
I need to know the make and model # to more accurately help you. First and foremost, you will need to thaw your holding tank with a steamer...do NOT use heat gun or hair dryers. The problem could be one of several but I would start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze. I've seen this with LG's and GE's. They make a special heater modification for units notorious for this latter problem.
Nov 25, 2008 | Refrigerators
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE older ice maker won't make ice
pull the cover of the front of the ice maker. there should be directions as to what way to turn the main gear (use a philips screw driver). advance the ice maker until it starts to run on its own. if water comes in at the end of the cycle then you need a new ice maker. if no water comes in check to make sure the fill tube is not frozen. if it is clear replace the water valve.
Good Luck,
Todd
Oct 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
155 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
