Question about Singer Electronic Sewing Machine
Manual singer sewing machine 560
Tension positions for top and bottom bobbin
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
bargainbox
  • 1388 Answers
SOURCE: bottom stitch all gummed up
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Dec 28, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Singer 4423, brand new, bobbin thread coming to the top and top thread to bottom?
Possibly a threading issue.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread the top from the beginning.
Verify that you have followed the thread path exactly.
Check the bobbin to see that it is turning the correct direction in the bobbin case.
Set the top tension to the midway point on the dial.
If bobbin thread appears on the top of the fabric, loosen the top tension. If top thread appears under the fabric, tighten the top tension. FWIW, using two colors will highlight tension issues that would not be apparent when using the same color thread. It is generally recommended, when stitching, to use the same color when sewing to avoid making the stitches more obvious.
If you are using thick or thin thread, there will be a difference in the tension results of stitching. Also, fabric will affect the tension results.
Apr 30, 2018 | Singer Sewing Machines
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Have a singer H74 and the bobbin is stitching on the top side of the fabric also deco stitches are not coming our clear what am I doing wrong? Thx
Whenever that happens, it means that your top tension is tighter than your bottom tension, so your bobbin thread is being pulled to the top. That happens occasionally, and the solution is to loosen your top tension. Tensions are a BALANCE between top and bottom. Should this happen ALL the time, you could consider adjusting your bobbin tension, but when it happens occasionally, loosening your top tension works just fine.
Feb 28, 2015 | Singer Sewing Machine, Model H74
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
Looking for sewing machine manual for singer sewing machine model 6218. The bottom bobbin tension is so loose that it forms many loops under the fabric.
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
Oct 21, 2010 | Singer Sewing Machines
Seat the bobbin & adjust tension on Singer 9018
basic tension instructions apply...bottom tension should be moderate, thread should pass when holding thread and dangle the case. Top tension should pull bottom thread JUST to the top side of fabric. thread bobbin case counter clockwise.
May 31, 2010 | Singer 3116 Simple
I have borrowed my Mother's Singer Machine # 1022 to finish a project. I have never used this model before. The bobbin threads are way to loose, which dial adjusts the bobbin tension? Also, what is the...
First check if the top thread tension is too tight. Make sure that there are no burs or other damage on the needle. Next check for lint or bits of thread between the bobbin case sections. Remove the bobbin and run a small screw driver or needle between the two silver plates on the top of the bobbin case.
Check if the machine is sewing properly before trying this next step. Find the right hand screw on the side of the black bobbin case. Make sure that this set screw is tight. Turn it clockwise. Next find the left hand screw on the bobbin case. Turn the screw 1/8 turn clockwise to tighten. Test the thread tension. If the bottom thread is still loose, turn this screw another 1/8 of a turn. Test the tension again. Do not over-tighten the screw. This can damage the bobbin case. Some sewing machine parts stores do have a replacement bobbin case available. One source is http://www.sewingpartsonline.com/singer-1022-sewing-machine-parts.aspx .
The dial with 0 F 1 2 3 4 controls the stitch length. Use the 0-1 position for zig zag Satin stitch (At 0, these stitches are very close together). Position 4 will give a longer stitch for basting. See page 4 of the manual (page 8 of the PDF) listed below. In the center of this dial is the reverse button.
Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 1022 is http://www.singerco.com/uploads/download/62d051dd5c881663ac19c0a587e679184d936b18.pdf .
I hope this helps.
Aug 22, 2017 | Singer Sewing Machines
Singer Electronic Sewing Machine Logo
53 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
