Question about Samsung Washing Machines
Red key symbol and unable to open door on Samsung 7.5kg front loader purchased today
  • 1294 Answers
SOURCE: Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Posted on Sep 21, 2007
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
  • 1531 Answers
SOURCE: my front loader washer door will not open a lock
there is a chance that there is something stuck inside the drain pump.use a shop vac attach it to the end of the drain hose remove all the water.unplug the unit and plug it back in this should unlock the door. check the drain pump for foregin objects such as small nails bobby pins,drill bits anything that could stop the impellar wheel from turning.if there is nothing in it then you might have a bad drain pump.
Posted on Sep 21, 2009
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Posted on Oct 25, 2009
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Front loader washing machine door won't open
try unplugging the machine to reset it.
Feb 27, 2012 | Samsung Washing Machines
My samsung front loader door will not open it is stuck in the locked mode
very common with the samsung front loaders the door interlock needs to be replaced.
Jan 11, 2011 | Washing Machines
Red lock symbol displayed, I cannot open the front loading door, how do i open?
you should be able to press the signal and soil level buttons for two to five seconds and it should ulnlock
Jan 01, 2011 | Samsung Washing Machines
My front loader washer door will not open a lock symbol is being displayed tryed unplugging did not work
Sep 21, 2009 | Samsung WF328AA Front Load Washer
Mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
May 10, 2009 | Samsung WF337AA Front Load Washer
Front loader washing machine won't unlock door
Remove three screw at bottom of washer, pull of lower panel, reach up on right side just under the locking mechanism and bull ring down. door should unlock.
Jun 08, 2008 | Washing Machines
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
65 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
