Question about Xerox ColorQube 9303 Printer
Cleaning unit fault - Xerox ColorQube 9303 Printer
Sony cd player cdp-ce275 hangs on all disc shuffel. how to fix
The fault is with its optical pickup unit. Insert a lens cleaning disc into the player and play it for at least two times. This must rectify the the problem if the fault is with dust of dirt. If not, replace the optical pickup unit.
May 27, 2012 | Audio Players & Recorders
Tip
BMW Motorrad Fault Codes
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
Oter fault codes here http://bike-manual.mozello.ru/bmw-motorrad-fault-codes
on Dec 20, 2016 | Motorcycles
Dosen,t play only continue loading
Hell
It will be duet to the fault to its laser pickup unit. clean it, by inserting a lens cleaning disc into it. If it do not help you, replace the laser pickup unit.
Mar 09, 2012 | Televison & Video
Washer will only go to rinse cycle and now wash cycle
Possible fault in the program controller unit. It will be good to have all the connections - electrical connections- reconnected with cleaning of all contacts.
also check on the controller section and the inlet valve and motor sections.
Once the cleaning is done connect and test. if fault occurs the controller unit is faulty.
Feb 15, 2011 | Kenmore 24032\24036 Top Load Washer
RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE...
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Oct 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Jvc dvx8 video camera head cleaning fault
The cleaning tapes that are available are often ineffective. The heads are cloggd up and need to be cleaned professionally. The only way to clean these now is top open up the unit. This should only be done by a service center as it is easy to cause more damage. Also at the same time, the alignment should be checked.
Dan
Jan 07, 2009 | JVC Cameras
Ricoh ft 3213 printing problem
Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
  1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
  2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
  3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
I hope this helps you
Thanks J
Jan 18, 2008 | Office Equipment & Supplies
Whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 23, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Oct 16, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Error 3001
I have brand new DV600E unit for sale, send me email for more information.
Apr 30, 2007 | JVC BR-DV600E VCR
Xerox ColorQube 9303 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
