Question about Bosch Nexxt WTMC 3300 Electric Dryer
How to remove the back of a bosch vision dryer
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
Dryer wont heat but thermostat is good. what can i do next
Check for power at the gas solenoid valve, work your way back to the high limit thermal cut off
May 16, 2015 | Bosch WTVC5530UC Vision 500 Gas Dryer
My vision 300 dryer works but no heat ?
I would not call that working then why do you .call a service tech.
Mar 08, 2015 | Bosch Vision 300 DLX Series WTVC4300US
Dryer turns back on after cycle is complete
Mike, this is a anti-wrinke function of the dryer. You can turn this function off. Without a full model number I can only tell you to refer to the owners manual to disable the anti-wrinke function.
Apr 20, 2014 | Bosch Vision 500 Series Front-Load Washing...
Bosch Vision 300 series type WNB T80 - The dryer stops every ten minutes. I have to keep turning the machine back on. I have cleaned the lint filter (vacuumed out the lint filter area) and replaced the...
Do you use dryer sheets? The chemical in dryer sheets seal up the little holes in the lint filters. To test, take the lint filter to the sink and see if it holds water. If it does, give it a good scrub and toss out the dryer sheets.
Oct 29, 2013 | Bosch Dryers
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
A locked key sign has come up on our bosch dryer display. wont turn on just bleeps at us. we are not sure what this means or how to turn it off. thank you for your help.
If this is a vision dryer, the bosch user guide says to press and hold the start/pause button for 4 seconds. This should unlock the dryer.
Jan 07, 2011 | Bosch Dryers
How long can the duct be for Bosch dryer?
as long as u want as long as there are not allot of bends, the straighter the better.
Jan 29, 2010 | Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
49 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
