The detection mechanism is as follows:
· The machine reaches the auto-off time.
· The solenoid mounted inside the main switch turns on for 3 seconds.
· If the main switch does not turn off, the solenoid is turned off for 1
seconds.
· The solenoid is once again turned on for 3 seconds.
· If the main switch does not turn off at this point, the solenoid turns off
and E940 lights.
Possible Causes -
The main switch is defective.
The main control board is defective.
1. Turn on the main switch.
2. Enter SP5-810 (SC code reset) and press the Enter key.
3. Exit SP mode and turn the main switch off and on.
You might try rebooting it by pushing * and # together, at the same time for about 10 seconds. You'll see the display go dark for a second then come back up again.
I took cartridge 31 off the printer (Lexmartk X5450) several times to clean it with ink cleaner (it...
(More)
I took cartridge 31 off the printer (Lexmartk X5450) several times to clean it with ink cleaner (it wasn't used for some time and black ink didn't run) and the printer started displaying message ''incorrect cartridge''.
my mfs 495cw printer isnt printing photos correctly. it prints on paper fine however when i tried to...
(More)
my mfs 495cw printer isnt printing photos correctly. it prints on paper fine however when i tried to print a photo it leaves a lot of wet ink and its the quality is horrible.
