Question about IFB ELENA
Pressostat error - IFB ELENA
My air compressors filled up with air and shut off when the air got below a certain psi and did not kick back in to fill the tank can you help me.
Pressure problems can be several pressureline leaks
If an air pressure switch (pressostat) does not return replace the pressure switch a gray colored or white or black colored box with the powercables comin to and the power knob on it red black gay or other color. that is the problem itself in this case . the mechanic jumped not up it hangs , best is to replace the complete part.
If the compressor filling the tank and when its reached the pressure and it blow from out the safety valve then the pressostat its too high adjusted. there is a max pressure on the valve to read is it blow off below the max replace the safety valve.
Is your pressure is build up but it blow out the Pressure relief nipple its a part of the pressostat in most case , the your Non-return valve on the tank is dirty or by dirtable metal parts from the pressure line membrane parts .
Jul 19, 2017 | Psi Air Tools & Compressors
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Where is low port on xc90
IF it has one it will be in the low side line just behind the passengers side headlight.
Volvo uses the pressostat valve to read the low side pressure via the diagnostic computer. IF it's a simple evac and recharge you only need the high side port.
FYI, if it's low pay attention to the weld where the condenser and accumulator support attach. they're know to crack.
May 05, 2014 | 2004 Volvo XC90
What is error code 4 on a Candy washer (GO 682)? Stain Vanish and 90m light are flashing 4 times.Thank you.
the problem may be caused by too much dirty inside the washing machin such as soap and or calc.
it can be the water level pressostat faulty
Apr 07, 2011 | Candy Washing Machines
After working perfectly for almost 10 years, My Miele dishwasher G 664 doesn't fill in water. We replaced the Pressostat and it didn't solve the problem. My technician suggests that the motor is off and...
In my professional opinion with a 10 year old unit. Buy a NEW unit, with a warranty, and do not spend good money after bad, as they say, a unit of this age will simply continue to fault, over and over, as it gets older.
Aug 03, 2010 | Dishwashers
Code F09 ???
Hello, the F09 code simple means an electronic communication problem with the washer..
To remove the error display, press pause/cancel twice, if pause/cancel does not work
1. Unplug washer or disconnect power for 1 minutes.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press start.
If the error on the display, please call for service
May 20, 2010 | Whirlpool AWM8143 Front Load Washer
The washing machine was half way through a cycle and then stopped and displayed F09 fault what does that mean..
this is what is called an Overflow failure error code. you will need to check or replace the pressostat.
Mar 14, 2009 | Whirlpool AWM8143 Front Load Washer
Dishwasher will not stop washing
The problem is the pressostat which is part of the water level system. Either the pressostat needs adjustment or replacement. the air trap at the back of the unit in the sump area may be loose or broken, this should be inspected. refer to .
Jan 15, 2009 | Jet Tech Systems 24 in. 737 Free-standing...
Too much water entering drum.
I am not sure what the problem is... one passibillity :It can be something blocking the pressostat (pressostat ... is the thing regulating the water... when the water is rising... ear pressure will increase in a small pipe leading up to the pressostat.) What can it be?...
if you have lime in your water it can block the intrance to the pressostat after som years. test if this is the problem..
if this is the problem . you chould also clean you machine with acid. Do a wash with asid on 95 degrees (ask for this in a washingmachine shop).. ..
Dirt: take out the small thin pipe(of gum) and clean it.. (the dirt blockin is always nearby drum)
Dec 30, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Hotpoint washing machine
try to change a water level meter(pressostat)
Jul 06, 2008 | Washing Machines
139 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Eric Sutherland
Ken Strite
Ken Strite
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
