Question about Galaxy Radios DX-959 40-Channels Base CB Radio
Adjust modulation galaxy radio - Galaxy Radios DX-959 40-Channels Base CB Radio
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Vr 14 is high vr 18 is low vr 16 is fine tune it. but there is a procedure to it so you will need the manual. go to www.cbtricks.com in the left column you will see radios , schematics , manuals.,click on it find g then click the go to galaxy dx and look at the list til you find dx-959 open it up and you will be in your glory. good luck.
Posted on Nov 29, 2014
Where is the modulation pot on the dx 919 v 16
did you use a meter when you set the pot? there are two pots to adjust . one for high modulation and they other for low modulation . Apparently you didn't read the schematic good enough.
Feb 27, 2015 | Radio Communications
Galaxy 44v has no modulation
If its a used radio it could be a number of reasons.If its a new radio it could be half those reasons.. Assuming its a new radio you need to remove the bottom cover and with a copy of the service manual you need to adjust the modulation .
Sep 02, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
Adjust modulation pot cb
4 watts on am and 12 on ssb the modulation pot isn't going to help you . go to www.cbtricks.com and get the service manual.
Jul 27, 2013 | Galaxy Radios DX-979 40-Channels Base CB...
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
Jun 18, 2013 | Galaxy Radios DX-33HML 40-Channels Base CB...
44v galaxy would like to know how to properly adjust my radio for optimum modulation
VR -13 ,14,15. there is special adjustments to these that you must know so I would go to www.cbtricks.com and get more information on this radio.
Jun 14, 2013 | Radio Communications
Adjust modulaion pot dx919
TO ADJUST MODULATION IN THIS RADIO THE POT IS MARKED
V-16 TURN CLOCKWISE ,CAUTION VERY FRAGIL BE VERY GENTLE SIR
Feb 24, 2013 | Galaxy Radios DX-919 40-Channels Base CB...
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Radio has 10 watts on side band
Readjust your load coil. You should never attempt this without a load and a watt meter.
Dec 30, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
186 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
