Question about Bosch Vision 500 Series WTVC533AUS Electric Dryer
Bosch 500 visions series wont heat - Bosch Vision 500 Series WTVC533AUS Electric Dryer
5 Suggested Answers
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Posted on Oct 04, 2010
  • 39 Answers
SOURCE: Where do I find the
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Posted on Mar 02, 2011
  • 25 Answers
SOURCE: bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Posted on Jan 18, 2012
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
Dryer wont heat but thermostat is good. what can i do next
Check for power at the gas solenoid valve, work your way back to the high limit thermal cut off
May 16, 2015 | Bosch WTVC5530UC Vision 500 Gas Dryer
How do I find the codes on my washer bosch 500
On http://www.onlineonderdelenshop.nl/blog/storingcode-fout-code-bosch-siemens-wasautomaten-wasmachine/ you can find some Bosch codes in Dutch with some explanations.
Oct 19, 2014 | Bosch WFVC540SUC Vision 500 Washer in...
Bosh 500 series dryer wont heat and rest button wont push in.
then u definately have a problem,and would be better getting a tech to look at it for u
Jan 19, 2014 | Bosch Nexxt 500 Dryer
Bosch vision 300/500 dlx series washing machine: how do you remove the front kick plate to access the pump?
Bosch vision 300/500 dlx series This video will show you how to change the pump washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 08, 2012 | Bosch Washing Machines
Bosch Vision 500 Series WTVC533AUS Electric Dryer Logo
151 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
