Question about Exercise & Fitness
I have a Proform 6.0 ET Eliptical. It peddles very hard and does not seem to change whether I set it on 1 or 20. It is new... How can I fix it?
Can you help?
ercupa190
  • 12223 Answers
SOURCE: need instructions for the proform eliptical
http://www.youtube.com/watch?v=He3CzByiqQk
http://www.youtube.com/watch?v=s3i1Cp3K5rc&feature=related
please see the video for proform eliptical.
sincerely.
e.cuadra
Posted on Nov 04, 2011
ercupa190
  • 12223 Answers
SOURCE: i need instructions for the proform eliptical
GO TO THE PAGE FOR PROFORM:
www.proform.com
they have videos, in you tube, check it please.
E.CUADRA
ercupa190
  • 12223 Answers
SOURCE: proform ZE9 eliptical screen blanked out evry thing else works
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Posted on Aug 01, 2012
ercupa190
  • 12223 Answers
SOURCE: my proform spacesaver 500 eliptical is making a clicking sound
follow this steps and fix it. God bless you
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Posted on Nov 30, 2012
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
use the next steps:
Step 1
Step 2
Step 3
Step 4
Step 5
Jul 31, 2012 | Exercise & Fitness
I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
sincerely. God bless you
Apr 18, 2012 | Proform 6.0 CE Rear Drive Elliptical...
Pro-Form 500 LE resistance is reversed
The problem I am encountering is that the resistance doesn't seem to change. Whether I am on 1, 5, or 10 it seems the same. Any ideas for ME?
Mar 14, 2012 | Exercise & Fitness
Need instructions for the proform eliptical machine
sincerely.
e.cuadra
Nov 03, 2011 | Exercise & Fitness
I need instructions for the proform eliptical machine
www.proform.com
E.CUADRA
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
I have the proform 10..8x recumbent bike and the left peddle has started to click what can i do to fix this problem?
U would have to take it apart and clean or replace any bd bearings or just buy a new peddle
Feb 16, 2010 | Cycling
CardioStyle ET 150 Eliptical Trainer
It's at https://www.dixiesales.com/ipl/935/84-0101%20English%20Manual%20-%2009-24-07.pdf
Sep 24, 2009 | Exercise & Fitness
Exercise & Fitness Logo
16 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
