Question about Coffee Makers & Espresso Machines
Delonghi infuser stuck
Prima donnas
ginko
  • 19396 Answers
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
Posted on Aug 20, 2008
SOURCE: My Delonghi Prima Donna won't dispense milk only steam.
I've just had the same thing happen to me today. The one thing I noticed was there is a broken rubber ring which appears to have fallen from around the milk spout.
I'm off to the Service Centre tomorrow so will hopefully have some good news shortly...
Posted on Jan 03, 2010
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
SOURCE: I own a DeLonghi Prima
The Blue LCD display on my DeLonght Prima Donna has failed - how do I get it fixed?
Posted on Oct 03, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
Where on the delonghi Prima Donna s delux coffee machine is the "coffee bean empty" sensor
look in the bin hopper for a clear panel and wipe it off good I hear they get dusty
Nov 20, 2015 | DeLonghi PrimaDonna S Deluxe Super...
Delonghi prima donna esam6600 the lcd display stop working
If you are proficient at working on these machines, you should be able to get a replacement display from your local Delonghi agent to fit yourself. The fault is likely to be in the onboard driver or the display itself. Simply replacing it should sort it.
Dec 08, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi problems
turn off the machine and after 2 minutes turn it back on
Sep 01, 2014 | DeLonghi Prima Donna Avante ESAM6700...
Have a delonghi Prima Donna 6700 coffee machine and get this message
Hi there coffee person.
Have you tried disconnecting the machine from the power supply. As well as that check if there are enough coffee beans in the bean in the compartment and enough fresh water in the water tank. Not only this but is the compartment with the coffee "tablets" - full or empty. Fill or empty accordingly. Connect to power again, if the machine does not work the only advice have from here is "to clean the machine" as described in the manual or as you are used to.
Good luck
kolbrun
Mar 03, 2012 | DeLonghi Prima Donna Avante ESAM6700...
Recently descaled delonghi prima donna not frothing
milk unit pipe s blocked needs strip down...07779933829 uk we repaire
Jan 15, 2011 | DeLonghi Prima Donna Avante ESAM6700...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Coffee Makers & Espresso Machines Logo
12 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
