Question about Pioneer PureVision Pro-1000HD 50 in. HD-Ready Plasma Television
Black pioneer tv screen no picture
Controls will lite up and provide menu option but otherwise screen is totally black. The tv is about 7 years old but never a problem prior. It also wont display anything from on demand or a dvd but sound works perfectly. Any ideas what to check or how to fix?
JAN_yuanjia
  • 470 Answers
SOURCE: Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Posted on Nov 16, 2008
roety
  • 585 Answers
SOURCE: Top half of screen malfunctioning - Exactly the same as dclurman
You have a bad upper Y buffer board, not sure what the part# is, but they usually sell for btwn $200-$400
thanks
Eric
Posted on Aug 26, 2009
Turk_97
  • 131 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
  • 8457 Answers
SOURCE: Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 31, 2010
Replace a broken screen on a pn60f5500
It will be best to buy a new TV; instead of replacing its LCD screen; as it might cost 2/3rd of the total cost of a new TV.
Feb 25, 2015 | Samsung 60" Series 5 Plasma HDTV -...
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Black box on top of picture
This sounds like the text function is turned on in the closed captioning part of the menu. If the remote has a separate captioning button press that until captioning and text are off. Otherwise the caption/text settings are in the customer menu. Go into the menu to the captioning options & shut captioning/text off and see if this corrects your problem.
Nov 09, 2009 | JVC AV-27D201 27" TV
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Not getting a picture from a Samsung 46" LCD TV
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
Jun 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
White line
This is cauced by a collaspe of the vertical output circuit. Normally a relatively easy/quick fix by a skilled repair tech. If you have a nice quality set that is less than 7 years old, it might be worth fixing, otherwise, you might want to consider getting a new one.
Give a call to a local service shop and tell them what TV you have and the problem and see what they provide for an estimate to repair, it might be worth doing and it might make your decision easier to go buy a new one.
Jul 29, 2008 | Sony KV-32XBR450 32" TV
Night time scenes have become almost impossible to see.
I had the same problem. Figured the 8 yr. old set was on it's last legs. Read everything I could find and nothing helped. But, luckly I did the following and it's like new again! try the following: Press MENU, selectSETUP, select DPO, set it OFF. DPO automatically controls Contrast, BLACK LEVEL (Brightness) and Color. Now press Menu, select PICTURE, then select BLACK LEVEL and run it out to plus 25. your picture should be brighter. Then adust Contrast,Color and Black level to your liking.
Jul 13, 2008 | Pioneer SD-532HD5 53" Rear Projection...
We own a Toshiba Regza 42" direct view LCD TV. We have owned this since last November (bought as a Christmas gift). This TV was working great until last night (7/7). Powered it on and for a split...
Unfortunately there might no be a fix for this type of failure unless the LCD is open and perform a few measurements in the circuitry. Since the TV is less then a year old, I would suggest to contact the vendor or manufacturer to have it repair under warranty, most electronics devices carry one year warranty.
Let me know if you require further assistance.
Jul 08, 2008 | Televison & Video
Pioneer PRO-510HD Elite
since your tv is 6yrs old it could be that the video circuit has cold solder that needs to be resolder if that does not work then a focus on the video circuit by replacing the component there, it could be an ic or transistors or diode.if you are not a tech get one to look at your set.good luck.for further help email me at nicodhem@yahoo.com
Apr 06, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer PureVision Pro-1000HD 50 in. HD-Ready Plasma Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
