Question about Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer
0 characters
1 Points
Phone showing Check Phone Line w,hat does this mean. Cannot use phone
The message is indicating a problem in the line between your phone and the outside world.
Jun 30, 2016 | Phones
Problem with my house phone line
if You are line owner contact the customer service of your phone provider if you have a limit on the line. Ask to remove restrictions if it is posible.
Jul 20, 2014 | Panasonic Phones
Why am i unable to connect to my motorola L603m and theres no power supply
Contact The point of purchase. The phone should come with a charger. Or you can contact Looking For Help to find a replacement.
Motorola Support
May 12, 2014 | Motorola Mobility L603m Digital Cordless...
Unable to dial outsife line on mlx-20L
test the jack box. Use another phone for to proof the jack box. IF THE problem persist, the problem is the line .Call the company of phone. +48Vdc will be presente in the main lines. if is missing call the company.
God bless you
Jul 31, 2012 | Avaya Legend 20-Button MLX Digital...
The phone rings once, then stops ringing
Remember to also disconnect direct tv receivers. I had the same problem untill I unplugged them from the phone line.
Jul 31, 2010 | Uniden Cordless Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
Very low volume on 'handsfree' option; whereas the vol. for the line button can be quite loud
The Volume function of that phone is controlled by the up down vol button on the phone. the only time it does anything is when that function is being used. ie. when you have the handset in hand the vol buttons control the handset volume, while the phone is ringing the buttons control the ringer volume etc.
Oct 09, 2009 | NorStar M5316 Phone, NT4X42 (Refurbished,...
No dial tone
It sounds like you have the wires hooked up wrong. Check both ends of the wire.
Jun 01, 2009 | Nortel Meridian M7208 Corded Phone
Answers two phones at one time
get the first one and second one and talk at one time
Jan 10, 2009 | General Electric 25922GE3 Cordless Phone
Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer Logo
22 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
