Radiogram manual - Audio Players & Recorders
Vintage radiogram tape cassette button jammed down
You will have to do some disassembly to release it unless it is broken, in which case it will have to be replaced.
Jan 03, 2018 | Vintage Audio Players & Recorders
Garrard turntable in blaupunkt monte carle radiogram - needs new spindle - anyone know which model turntable was used by blaupunkt and where I might get a spindle?
If you can identify the unit you will have to shop at places that sell vintage gear and it will cost a pretty penny for sure.
Aug 31, 2017 | Audio Players & Recorders
I need a schematic for an RCAA Victor model IVF 07 serial 1215357 (1453)
Hi check inside the cabinet some of the old radiograms had a rough schematic inside . C photo .cheers
Aug 22, 2016 | Audio Players & Recorders
HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Jul 27, 2010 | Audio Players & Recorders
I have an Ambassador radiogram, everything seems to be working but there is no sound, I do not know if it is the radiogram or the speakers. Please Help.
"everything seems to be working but there is no sound"
If everything was working you would have sound.
Troublshooting these sets is hard over the net. Basic troubleshooting involvs, verifying parts are in good order. Testing the speaker. Test the transformer and power supply. In older sets, you may need to replace the filter capcaitors.. If a cap is shorted, you might have already taken out your power transformer.
This is a common mistake people do. They power up an old set to 'test', in the process they burn up hard to find parts.
If all this is over your head, first please see:
http://antiqueradio.org/powerup.htm
I assume you are in the UK? If so, I'd suggest you join this fine group. They can steer you in the right direction.
http://www.vintage-radio.net/forum/index.php
I can probably get your set running, but it's impossible to do over the net.
If you are in the USA, you may join here:
http://antiqueradios.com/forums/
Another fine group of helpful folks there. So, I'd suggest that you do not power up your set again, until some basic checks have been done, and at least the filter capacitors have been replaced.
Often replacing the filters will result in a working set again.
Mar 10, 2010 | La Crosse Technology E. Howard Ambassador...
We need a manual for an old Philips radiogram to assist in the restoration process please. It was made in Great Britain it is a Philips type AG 10006-15 No: M13395. If anyone can help it would be greatly...
If you know roughly which year it was made you might be able to track it down in Newnes Radio And Television Servicing Books. They list models made in each year. For example 1960-1961 will feature the models from those years, but you might also find it in the next book (1961-1962) or the previous (1959-1960).
I believe they still make them, but the are expensive, however many public libraries have full sets and will allow you to photocopy pages.
Feb 06, 2010 | Electronics - Others
Can not get 45's 78' or 33's records to drop
The metal upright (called a keeper) at the top may be bent or stuck up with grease or other mess.
However if the center hole in the record is oversized records will drop too. And there's nothing you can do about that.
Jan 05, 2010 | Audio Players & Recorders
 Grubhead
Grubhead
