Question about Amana 3.2 cu. ft. Top-Load Washer
I HAVE An amana washer lw6501w2 its like it getting no juice to it
4 Suggested Answers
SOURCE: belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Posted on Feb 28, 2009
  • 67 Answers
SOURCE: I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
Posted on Aug 11, 2009
marka19
  • 1430 Answers
SOURCE: replace drain hose on mod LW6501W2 washing machine
Enter model # at www.appliancehelponline.com for diagrams and illustrations.
Posted on Apr 09, 2010
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin ยท Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
Oct 19, 2009 | Amana Washing Machines
Aug 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
The water pump won't come off
Hi, It sounds like the pump is froze on the motor shaft. It will take a long flat blade screw driver and pry the pump off. try and wedge the screw driver between the pump sleeve and the motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Washing Machines
Belt amana washer replace mod lw6501w2
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Model LW6501W2
Sounds like the outlet pump has siezed up due to having been stood for so long. You may need to take the pump apart, clean the shaft & reassemble. Or, you could try a spray with WD 40 on the pump. TURN POWER OFF FIRST
Oct 26, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Amana 3.2 cu. ft. Top-Load Washer Logo
18 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
