Question about Panasonic AG-1980 S-VHS VCR
Power down - F 04 error
When I plug in my AG-1980P, it will power up, but then immediately powers down and gives an F 04 error in the LCD display area.  Any suggestions?
Thanks,  Karen
  • 2 more comments
  • meetingguy Nov 16, 2007
    I record town meeting once a week for 3 hours each night.. I use 2 Panasonic 1980 decks. The past couple of weeks, After recording the meeting on T160 tapes, I go to change the tape & one of my machines powers down & wont turn back on. I have an error F04 message. I actually have had a tape get suck in the deck at the last meeting. Any help?
  • Anonymous Jan 13, 2008
    During legnthy recording and editing the unit powers off and the display reads F 03. I power up again and the unit deeps powering off with the same F 03 error. What is happening?
  • Anonymous Apr 25, 2008
    I have the same problem.
    Inspection does not show anything
  • litemninyusz May 11, 2010
    1st occurence:
    I'll not recorded to any video casettes recently. The solution of sedonix is helped, but I needed at least 30 minutes!
    2st occurence (still not fixed):
    The solution of sedonix is not helped! I'll recorded to 2 video casettes recently. After the 2-3st recent record to the 2st video casette, I've replaced the video casette and F 04 problem still occurs after trying sedonix's solution for at least 1 hours-1 hours 30 minutes!
    Help please!
    Thanks!
    litemninyusz (litemininyuszika)
Problems with F03 - To exchange key of way.
Posted on Aug 20, 2011
  • tele_eletron Aug 20, 2011
    Sorry, To exchange key of service
For me, needed more time... at lease 1 hour!
Posted on Jun 26, 2008
  • 579 Answers
These are good old VCRs probably in need of a belt overhaul.
Try unpluging the unit for 2 minutes and see if the error message is reset.
Posted on Dec 28, 2007
A strange problem with a TEAC AG-790A amplituner
Maybe in your AC outlet is not correct voltage. Measure the voltage, check connection all the wires. I had a similar problem with my TV - there was loose connection (released wire) in the electrical distribution panel.
Apr 02, 2015 | Teac Audio Players & Recorders
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Panasonic AG-DS550 VCR shuts itself down about 2 seconds after switched on. No error code appears in that brief interval. Toggling the power switch immediately is ineffective, but after waiting a while,...
This is a typical symptom of a power supply failure. There are some self-checks performed at power-up that are not completing correctly. Were there any symptoms before the complete failure? Often, the units start to behave strangely before complete shutdown. The power supply failure is tied to defective capacitors in most cases. These supplies are what are called "switch-mode" supplies and must oscillate to work. Defective caps will either not provide the kikcker to start the oscillation or prevent the oscillation completely. While there are other causes, this is the most common. AG units are professional decks and should be serviced by authorized service centers.
Hope this helps,
Dan
Dec 07, 2009 | Panasonic Televison & Video
Video noise pattern in playback panasonic AG 1980P VCR
It sounds like the video heads are dirty, or the tracking is off. I would first try adjusting the tracking to see if it can be corrected. If that does not work then I would clean the video heads using a video head cleaner (Radio Shack) You could also try a different tape to see if it that could be the reason. Also double check you video connections to your monitor to make sure they are good. If all of this fails than it may have to be checked out at an authorized Panasonic repair facility!
I hope this helps and good luck!
Nov 12, 2009 | Panasonic AG-1980 S-VHS VCR
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
Will not power up at all!
check the main board for bad solder connections near the power connection.
Oct 28, 2008 | Panasonic AG-DV1000 Mini DV VCR
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Good Audio, Bad Video
sounds like a loss of luminance -- check the analog yc pack for bad capacitors.
Mar 07, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 S-VHS VCR Logo
360 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
