Question about Rancilio Epoca ST
My rancilio epoca 2gp quit producing any hot water. In fact, I had just finished a draw and it wouldn't pull any more water through the group head. The steam wands worked for a short time, but now I am not getting any water. I have turned it off and tried pushing a reset button that has worked in the past. Please help!
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
  • 1089 Answers
SOURCE: no water through group head
Hi
More than likely your 3 way valve is stuck. It is located behind the front panel and when the 2 screws are removed it slides to the right. Unplug your machine before working on it. The 3 way valve is on the left and you can remove the dispersion tube on the bottom(unscrews) 14mm nut holds the solenoid on and you can slide the solenoid down the shaft. The big nut at the top of the shaft will unscrew and there you will fin the solenoid inside with a big spring. If its not stuck it will slide out and you probably need a new 3 way valve, but more than likely its stuck. Some times just tapping the nut on something hard will unstick the solenoid. Clean good and reinstall.
Posted on May 26, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a quite old la pavoni p3v2 110v 2000w two
Check the top of the group head there is a large bolt, within that is the metering jet and filter, that might be the cause of the blockage(either the jet is clogged or the filter is clogged). As for the full temp on the boiler what reading do you get on the gauge boiler side, it needs to be at about 1.2 bars.
Posted on Jun 24, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Posted on Jan 27, 2010
EsWorld
  • 1618 Answers
SOURCE: No steam from my rancilio silvia. unit about 2 yrs
Check the thermostats on the top of the boiler one of them tripped.
Posted on Feb 03, 2010
What happens when my new rancilio epoca coffee machine the water doesn't flush out.. It's a 2 group, the left one works, but the right one it's like water dripping only
Solenoid valve OR dirty and blocked shower screen OR dirty and blocked jet OR crap in the line to the R/H group..
Simple fix if you are in Brisbane.
May 25, 2014 | Coffee Makers & Espresso Machines
I have rancilio epoca e2. One side is not pulling a high enough temperature thus not good crema. Other side works fine
The only thing that comes to mind is the metering jet on the group as well as the reducers on the tubes bringing water into the group.
Jun 21, 2011 | Rancilio Silvia Espresso Machine
I am using a two group Rancilio Epoca espresso machine and would like to know how to set the water levels for the semi-automated buttons.
Hold down right most button for 8 - 10 seconds, then press button to program when you get your volume press button to stop repeat for next buttons, when done press stop button to get out of program mode.
Apr 19, 2011 | Rancilio Epoca ST-1 Espresso Machine
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
I am trying to get the sight glass out of a two group epoca. It looks like the metal nipples extend into the glass at both ends with no way to move the glass up or down to free it up. I don't want to break...
If the epoca is the same as mine, the sight glass is made from a plastic material and if you pull it from the middle it will bend and come away from the nipples without much trouble..
Jun 17, 2010 | Rancilio Epoca ST
Water doesn't come out from showerhead once the button is pressed - can hear the water pump going, the top of machine is warm so boiler is functioning.
Does water flow without the portafilter in place, if yes then check grind, if no then remove screw,filter and diffuser and press brew button, if water flows clean filter, if no water then the micro jet in the group head is blocked or the solenoid is clogged.
Oct 06, 2009 | Rancilio Epoca ST-1 Espresso Machine
I have a quite old la pavoni p3v2 110v 2000w two group machine that I have just finished a rebuild on. The machine goes to full temp on the boiler, the steam is great, but I can't get more than about 140...
Jun 21, 2009 | Rancilio Silvia Espresso Machine
Rancilio epoca - heating element continue to stick on
It's the thermostat for certain.
Te release valve is put there it be sure the tank pressure doesn't get too high such as to cause a steam explosion/rupture of the tank.
Jan 30, 2009 | Rancilio Epoca ST
No water coming out of coffee dipense head on one side
The metering jet and or filter on the back of the group is clogged.
Dec 11, 2008 | Rancilio Silvia Espresso Machine
Rancilio Epoca ST Logo
51 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
